charles have you not read any posts on sau....trent is they way to go ...make a booking,, drive car there go get something to eat while he puts the nistune board in then he will put your car on the rwd hub dyno and play nistune games with your car..pay him money drive out around $850.00 if nothing is wrong ..= better mid range power by maybe 30 killawasps (if you have a manual cant remember)and no speed limiter have fun and if your lucky you may get an sau discount ...good bloke will help you with some good advice on a few thing you can do to your car to get the extra power from nistune..DO IT YOU WONT REGRET IT ...ITS WORTH THE MONEY
Well I was always going to go to Trent, but I just didn't know whether he actually install himself or he sends it off to someone to do it.
Because I've received a NIStune chip in return for a job I did for someone :P
So yes, I will be going to Trent's. Am even thinking to sell my NIStune, then get Trent to do it all at once, as it works out to be cheaper lol.
if its just the board take it to trent he will install it into your ems it only takes him 1 hour and around 1.5 on the dyno...best bet is just to ring him and see what he says if you have the board just use the 1 you have then its only dyno time....nistune boards are worth around $350.00 i think....i have 1 in the stagea
Yeah Mick, I've gotten a quote from Trent.
$850 drive in drive out Inc board.
Or
$50 install and $650 for tune.
So that's why I wanna sell my board then just get the full package. If I use my board, I'll be paying $700. Or if I sell it for $250-300, I only have to add $550-600 :P
Or
Go for for$279.99 and you pay postage still cheaper than they will get it direct from adelaide post on stagea forums as i think people are looking for one
So how much is the RRP?
EDIT: Never mind, I found it. It's $286+postage.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
