S1 - 18x9.5 +14 245/40. The front just fits, but the rears are as close to the strut as you can get & are scrubbing pretty hard on the "heavily" rolled guards! (anyone who says they have bigger no worries, is full of it!)
* So a 18x9 +15 to +20 235/40 would be a pretty neat fit!
Edited by Zorro
  • Replies 134
I'm running 18x8 +35 front. Looks shit and +6 rear and it looks about right but I've only got 235/40r18 tyres so my speedo is severely wrong. Stupid tyre placard being wrong :@. Nice way to waste $1000 on the wrong tyres
235/40/18 is not that far off stock! I was using that size till recently, speedo was not out by much at all (<5kmh @ 100)!
~630mm (+- 3mm) rolling dia is roughly the stock size, 235/40/18 is 645mm (225/40 = 637mm), im now using 245/40/18 which is 653mm & is only slightly out, showing a lower speed on the speedo to actual velocity!
So dont stress too much! :thumbsup:
i notice that there is very little mention when people say "ive got 20x12"s with +18 offset and they're sick as" how how far they sit out the guard or if they still flush and MORE IMPORTANTLY wheather its an AUTO OR MANUAL!
Auto's have a much wider rear track than the fronts, so if you want them both to sit flush WITHOUT SPACERS you will need a low offset front (+20 to+34 would be ok) and a HIGHER offset in the rear (+35 to +42) thus meaning you wont be able to rotate your tyres unless you get them stripped off and fitted to the opposite rims. this is based on a 8-9 inch wide rim, diameter wont affect this. the wider the rim goes the lower the offset will need to be because you'll very quickly run out of room between rim and suspension but have all the room you like outside the guard (within reason). depending on weather you have bigger brakes or coilovers this may also affect the desired offset you want to run.
If you have a MANUAL (factory RS4-S or RS260 and not a conversion) then the track is pretty much identical front to rear and depending on the look your going for anthing from a +18 to a +35 will fit and clear standard suspension. when i got my RS4-S it had 17x8 with a +42 offset, the rears were very clearly fouling the struts (hicas didnt help). now i have 18x8" with a +34 offset. this offset clears everything easily and sits roughly where the standard C34 wheels do. i have plans to have it riding quite low in the future and with this offset i wont be fouling the guards.
according to my C34 tyre placard it says the OE fitment tyre is a 215/50R17 which is a 646.7mm OD, a 235/40R18 is 645.2mm OD which is near identical. My speedo is also out 12-15kms for anything over 100kmh. a 245/40R18 as already brought up will correct for this and is 653mm OD which is less than 7mm larger than the OE fitment tyre and a legal tyre size for a c34 (OZ legal limit is upto 15mm larger and 26mm smaller than largest OE fitment).
(edit: not sure if wider track is on all auto c34 stageas or just auto AWD c34stageas)
@pipster11 = +1
@lilcrash, have you tried swapping your wheels from front to back so instead of the front sitting in and the rears sitting out they both sit flush? (if yours is an auto of course, if not they would be worth selling to an auto owner)
Edited by RS4-S
I have a manual and I purchased my rims in those 2 offsets to get the look I want. The fronts are just 10mm further in then the rears. One day I will buy some 10mm spacers but for now I need to find new brake discs that won't warp on the first drive.
being an auto i would run maybe a 20 front and 34 rear, they should close enough to even and pretty much flush with the body. unless someone has the exact measurement for how much wider the rear track is.
correct me if im wrong but i think GTR 17"s are 17x8.5 +25?
Crap I thought GTR wheels were +18 or something close to that...
I actually have a set of staggered 18's that came off of one of my Starions, (with spacers), for a Skyline etc..
but being staggered, the ATTESA will probably have issues with them...
R33 GTR = 17x9 +30
R34 GTR = 18x9 +30
@Dr. J = ive seen people run staggered fitment rims with the same sized tyres front to rear on GTRs and an EVO, not sure if it caused issues but cant see why it would.
@Big Fella = is yours auto or manual?
i may be wrong but i was of the impression that auto= same track front rear and manual= rear 40mm narrower then front. and that is definately how my car appears.
Edited by lilcrash
quoting Big Fella: "I'm running 18 x 10 +15s all round, the fronts sit just in the gaurd, and ther rear would hang out with standard camber, running 2.2' seems all good tho"
is your auto or manual? how far did you have to pump your gaurds? what size tyres are you using? also what does 2.2 foot refer too?
Edited by Zorro
The Auto's rear is wider than the front.
Manual's is narrower than the auto's, but I don't know how it compares to the front.
mine is auto, rolled gaurds not pumped, 2.2 degrees camber on the rear, 235/40zr18
she isn't waht i'd call low tho, check the avatar!
Edited by Big Fella
wow ok im surprised you fitted that size wheel that easily, maybe there is a slight difference between s1 & s2?
have you got any photos of how your rears sit? 18x9.5+15 would sit nearly the same as mine, just a little further in. is yours auto or manual?
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
