BACK TO THIS
do any of you know what would be the best offset to run 19x9s on the nnm35 stagea
or maybe scottu could answer this is 19x9 to big for the stag
would you rather go 18x9 ?
these are my wheels spec's +36 - 19 x 8.5 ....245/45...... i'm running with no problems at all!....remember I have an AR-X so you will be a lower profile!!!
Hey Scotty what would be a good colour of undies to have on while driving the M35!!!
Edited by Jetwreck
  • Replies 134
hmm yes i see yours being the arx it is more of the off-road 4wd version so id say you would have more space in your wheel well? or are the flares just aesthetics and don't actually add to space
i ask him as he seems to be very knowledgeable on the nm35
if you want a apple you don't go to a orange tree
and undies ,what are those?
Edited by Sidius
i ask him as he seems to be very knowledgable on the nm35
if you want a apple you dont go to a orange tree
Use the search function bud...it will make things a lot easier for yah.....
why don't you go to a wheel shop or better yet use the search function!!!!
http://www.skylinesa..._1#entry5659197
http://www.skylinesa..._1#entry4729104
http://www.skylinesa..._1#entry4807211
and the list goes on!!!!!
Undies are what your mummy(Baaaarrrrbbbbraaaa) must still be removing to wipe your arse everyday!thumbsup.gif
Edited by Jetwreck
FFS!.....that he is!!!......but why don't you go to a wheel shop or better yet use the search function and read a little....every time you post it's on a past subject that is easy to find using the search function and will give you all the answers you need!!!!!
Undies are what your mummy must still be removing to wipe your arse everyday!thumbsup.gif
hahahahahha Lulz
FFS!.....that he is!!!......but why don't you go to a wheel shop or better yet use the search function!!!!
yawn here we go some one wanting to war not time for kiddies
or do i need to change your undies when i step up and you shrivel away
its called ask and i shall receive and i have so far withourt any issues thanks
not funny!!!
Looks like you might need to start using the search function a little more on SAU!
Edited by Jetwreck
FO little man!!!!....stop waisting everyone's time and do your own work!....for a change!
little ? assumptions were the failing point for better men who have tried :pwned:
any way no time for you , I do my own work I just ask people as they have the knowledge you must not as you had nothing of relevance to post
Edited by Sidius
still not funny!
you really don't use the search function do yah!!!
Edited by Jetwreck
lol.....nah it's not him.....he had a backbone!!!.....it's a sheepboy from across the water!!!
enough said anyway!
amusing the word little you use, get something fresh , excite me something new or go have a masty and let out your frustration
ill be in ausie for work in 2 months time so we could setlle this yet i dont think your balls would be any where big enough to match your words
i could use some practise before my kick boxing grading starts
Still not funny.
Edited by Jetwreck
:rofl2: :rofl2: :rofl2: :rofl2: :rofl2:
WTF is this shit?
Sidius, if you haven't found the answer you are looking for, get practical! start measuring your clearances ... work off the stock wheel to see what you can do in terms of width and offset.
http://www.1010tires.com/wheeloffsetcalculator.asp
Done, now stop wasting your time trolling on the forum and find the answer out for yourself.
WTF is this shit?
http://www.1010tires...tcalculator.asp
yawn
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
