  • Replies 134
What happens if I run 18 x 8? Should I be going 235/45/18 instead?
For M35's... (speedo values are based off the OEM speedo calibration for MY NM35)
STOCK RS
17" rims = 55 sidewall (total tyre height is 668mm) - speedo reads 10% fast
18" rims = 45 sidewall (total tyre height is 677mm) - speedo reads 8.7% fast
19" rims = 40 sidewall (total tyre height is 679mm) - speedo reads 8.3% fast
20" rims = 35 sidewall (total tyre height is 680mm) - speedo reads 8.2% fast
The ~10mm extra total height over the stock RS 17's fills out the wheel arch perfectly (particularly if you have lowered your suspension 20-25mm)
  • 1 month later...
STOCK RS
oh on this i think for the arx its +5 on the sidewall for each..
mine are 19" with a 45' sidewall.
and against the informeter with a GPS HUD dispaly it was i think 3-4km out at 100km/h
Would probably work out the same for RS and RX's
but your running a 19 and a 45 sidewall
thumbsup.gif.....but I am running a 245 as well!....more width....higher wall!
I may even go to a 35 sidewall if the new diff's throw out my speedo!wacko.gif....more go!
Edited by Jetwreck
nup....standard size for the AR-X is 225/55 18"
Yes, I know... I was referring to the speedo accuracy.
Mine reads 10% high according to GPS, as have most other RS's I have been in, so adding the extra diameter will get the speedo reading close to what Aaron stated.
oh....yeh the speedo is good in the AR-X until about 95km/h's....after that it out.....what's confusing is that the Infometer was spot on to my GPS.
well yeh, if it makes any difference mine is a 235/45... which was lucky coz no chance am i getting a 245/45 under my guards at my height.
but yeh, comparing with scotts even, im kind of glad that my speedo is only 3-4k's out..
Rolling diameter, not tyre width :)
235 or 245 shouldn't make a difference to your speedo.
  • 1 year later...
ok so if i change the 265 for something smaller will that be ok. and i just read about roling diameter being different from front to rear am i going to have a prob with this? and i just found out the rears are 18x9.5 + 38 offset running 265/35/18 and the fronts are 18x8.5 + 34 offset running 235/40/18. is this going to cause probs?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
