Hey guys
Just got a quote back from a shop to:
Cut and shape
Fit
Paint - stock white
Price - 1300
There is an item on the brake down called FRONT B/B - 300 . I have no idea what that is for so I will need to ask the guy about that
Any way is 1300 a decent price to fit and spray a aftermarket fiberglass front bar for an r33???? I was expecting 600 - 800
https://www.sau.com.au/forums/topic/351132-fit-and-spray-cost/
That sounds expensive to me! Got Quote $300 to respray my front bar (i supplied the paint and the thinner / clear) he supplied the primer and the undercoat $160ish for Thinner / Clear / 1 L of paint (he only used about 300ml for the whole front bar 400R apparently Midnight Purple spreads really well (have lots of paint left over) and i got quoted $80 to fit.
Should only cost you $500ish fitted! (midnight purple is $118 per liter, stock white will be much cheaper)
Yeah dude way too expensive.. I'd say that Front B/B would stand for Front Bumper Bar but who knows.. Maybe they quoted you for spraying a whole kit and then just broke it down to front bar only if you wanted to go ahead with the front bar only?
And do yourself a favour.. Go get more than one quote so you can compare..
Edited by .:: GimpS-R34 ::.
Where you get the quote from? Looking to fit a new front bar and sideskirts and one panel place quoted me about $360 max for fitting only. Trying to get more quotes.
Got that quote from DT Panels in Springvale they said $80 assuming that there will be no modifications made if it needs to be altered they will change you extra! my bumper didn't need to be altered, it was fitted on the car before i just needed it refit it which i actually ended up doing myself with a few mates. also got quoted by DT Panels $300 for spray and fitment of side skirts 400R on my r33 which i didn't end up doing i currently have M-Spec ones!
Edited by DarkRyda
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
