Hey Guys just bought a stock (aftermarket Pod and Cat back) R33 95 with 144000kms on it.
Its pretty clean but now when I idle it revs up and down and occasionally stalls. Other than Idle the car runs extremely smoothly and pulls fine.
My house mate disconnected and reconnnected this hose (in orange circle) and it ran fine for about 5 mins before falling back to the old problem, any ideas on what the problem is?
Thanks heaps for the help guys, really happy with the car except for this.
https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/
does the idle change when u move the steering wheel? If so, try cleaning the AAC valve, there's a tutorial on these forums
Nah doesnt affect it when I move the steering wheel, also gave the aac valve a good clean with carby cleaner and it didn't fix it, perhaps the valve itself is stuffed?
  • 3 months later...
is the factory bov recirculating still if not that will be your problem because factory bov spring to weak and leaks pressure when run to atmo
The spring isnt all that weak.. it will handle 300rwkw.
It is designed to leak at idle, so it leaks regardless of whether its plumbed back or not.
Id say that it isnt though. And because its leaking that air its overfuelling.
That, or the car is saying FUUU to all that silicon spray. haha.
  • 2 months later...
regardless of weather it fixes prob or not change
the fuels filter also clean the hot wire inside ya afm
if its dirty it will make a huge difference
also check the butterfly in the intake as it can get
a carbon build up and not seat properly in the intake
