The only difference between the R32 GTR & R32 GTS-T Brakes is the size of the front rotors. GTR being slightly larger :D
The R33 GTS-T has the same size front rotors as the R32GTR.
A set of R33 GTS-T Front rotors & calipers will bolt straight up.
The only difference between the R33 GTS-T & R32 GTR Calipers is the R32 GTR's have small fins on the outer edge. Nothing that will affect performance.
Price difference between the R32 GTR & R33 GTS-T Calipers is quite large.
https://www.sau.com.au/forums/topic/35119-r32-brakes-gts-t-gtr-upgrade/
  • 4 weeks later...
The R32 GT-R Sumitomo calipers are physically bigger than the R32 GTS-T ones, and allow the use of GT-R type rotors which are vented with the fins at an angle for better cooling on circuit, etc. Size diff between 32 GTST and 32GTR is 280mm vs 296mm ... much more surface area for heat dissapation. Also, better cooling than the straight fins of the R33 GTS-T rotors, even tho the size of the disc is similar. My 2c :)
  • 6 months later...
  Joel- said:
The only difference between the R32 GTR & R32 GTS-T Brakes is the size of the front rotors. GTR being slightly larger :(
Joel, have you done this brake swap yet? I am doing the same, did you use the standard master cylinder etc and just swap the brakes over?
Chris
  • 1 month later...
Can confirm that these bolt on no worries
Just put them on my car on the weekend, everything fits like its meant to be
I went for genuine R33 rotors, had them slotted and machined, and went for Racebrake's Comp 9 pads on the front and Comp 2's on the rear
Bedded them in last night, and they stop heaps better than the stock 32 brakes
Big reccomendation to other 32 owners who have done a few mods
no probs
I went through it all with a mate of mine who runs a jap wreckers, it came down to R32 GTR or R33 GTSt as the only bolt on options
Racebrakes does a bracket to suit standard R32 calipers, which lets you fit a R33/34 GTR Brembo size disk - 324mm!! I would have gone these, but my rims are 16x7.5 and the brakes wouldn't clear the rim. Price wise its pretty competitive, and a good option for those who want to run 17's all the time
Roy runs this setup on his road/track car with great success
Chris
R32 GTST
Master Cylinder diam (mm) - 25.4
R33 GTST
Master Cylinder diam (mm) - 23.8
R32 GTR (Non V-Spec,)
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9
So i dont see a need to upgrade the master cylinder if you have an R32 GTST and you will be using R33 GTST caliper or R32 GTR caliper.
Did around 30 laps of Mallala on friday, brakes where the best part of the car, felt very strong. Fuel pump problems meant I couldn't test them to there full potential, but it pulled up time and time again from 170+kmph no problems
I have an R32 GTS, which has hopes and dreams of becoming a gtst.. will be doing brakes + suspension + lsd before I do the engine.. so this is getting all the info down before I undertake it.. but i'm guessing a reco'd r32 gtst master cyl wouldnt be hugely expensive
  • 3 weeks later...
  • 3 weeks later...
  MR R32 said:
How much does it cost to have the rotors slotted and machined?
I was quoted from two different places and they are round the same I'd say you'd be looking at around about $40 each machined and extra $40each for slotted or cross-drilled.
Another question and sorry if it's been asked already, I was looking at getting a set of DBA 4000+ rotors for an R33 although I'll be looking at around $900 a set.
Whats the price comparison on a set of R33 GTR (2nd hand) rotors and are they much different from the GTS-T rotors in performance?
I have a set of Bendix Ultimates (pads) going in, should they hold up for track days? or can someone recommend something better for around the same cost?
Cost of Bendix Ultimates - $120 front $109 rear (pair)
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
