I did some stripped doors (evo) for track stuff here in WA and if you can get to them, you basically drill out the spot welds and then give em a bit of a bash and they come out. But to be honest they dont weight very much . (4kg at most in an evo)
For the tarmac rally car, as has Snowy, I left them in. I hope I never need em, but am happy to lug them around just in case. :)
https://www.sau.com.au/forums/topic/351192-stripping-doors/#findComment-5635568
Thought id let you all know what the results were.
The original doors complete were about 36kg. I have gutted them right out to a point where the door still should have good strength. I have managed to get them down to 15.2kg each without glass. The window weights just over 5kg. I am now going to get plastic windows made. Any idea what you reckon these should weigh?
Overall im pretty happy as this will be at least a 30-35kg saving for no cost oulay but for the windows and new mirrors. As a reference Sunline quote 3.5kg for their superlight carbon doors. These would be nice but just not practicle for the budget at this stage.
Anyway, if your thinking of gutting your GTR doors this is about the result you might expect.
Matt
https://www.sau.com.au/forums/topic/351192-stripping-doors/#findComment-5640835
Thanks Matt.... so that was 36kg each? Looking to get Carbon Fibre Doors, and I was wondering the total weight saving..... Thanks!
Can you fit steel intrusion bars to the carbon doors?
Also, does anyone know what a standard r34 boot lid weighs?
Edited by TwinTurboCelica
https://www.sau.com.au/forums/topic/351192-stripping-doors/#findComment-5640850
So how did you remove the intrusion bars,,,I need to do my R33.
I was thinking of a small wheeled 180 degree angle grinder and or my dremmel using a million cutoff discs.
Cheers
Neil.
We used mini cutting discs in the die grinder to cut the intrusions out of the R32 doors. I think we went through two disks cutting them out.
Talk to Brad about it cause he did most of the work.
https://www.sau.com.au/forums/topic/351192-stripping-doors/#findComment-5641726
Yeah I remember doing it well. GTiR is the same.
I used some small cut off wheels on my die grinder. I hve a shit load of them Neil. Can sacrifice a few next time I see you.
I also vote for the 9inch angle grinder which will go through the whole door skin nicely if not the whole door.
https://www.sau.com.au/forums/topic/351192-stripping-doors/#findComment-5641881
Kind of defeats the purpose...
There is a method to my madness. I don't want to fit a cage, but I think side intrusion bars are important for safety. Given you can get carbon fibre doors around 5kg, 4kg for intrusion bars, 5kgs for glass, 2kgs for add on trim... you could get a 36kg door down to 16kgs. Times by 2 doors, and you could save 40kgs. Well worth it IMHO.
https://www.sau.com.au/forums/topic/351192-stripping-doors/#findComment-5642030
Cheers
Neil.
I used a 5" angle grinder to cut the bar in half. had to be very careful when cutting close to the door skin but there is a few mm grace. I then drilled out the spot welds (about 4 per end per bar) and then used a hammer and chisel to break them apart. Took me a while to do the first door whilst i worked it out but not long at all for the second one.
The side intrusion bars were about 4kg per door.
Cheers,
Matt
https://www.sau.com.au/forums/topic/351192-stripping-doors/#findComment-5644399
+1 would not remove them unless you have a roll cage
I agree and this is a pure race car that has a very high end roll cage nearly completed in it. Otherwise i would leave them as is.
Also i cant see why anyone would bother stripping a car to this level if it was for the street. Would be a horrible noisy piece of junk to drive around in.
https://www.sau.com.au/forums/topic/351192-stripping-doors/#findComment-5644405
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
