Ok all you turbo whores...
I'm getting my AP Engineering PFC for my R32 GTS-T in the coming weeks and would like to know the before and after power figures for guys using this ECU.
Preferably results from guys that have had their stock ecu remapped and then opted to put in a PFC as this is my situation exactly. One would think the PFC would yield good results against the remap as the remap of the stocky is only a BASIC retune.
Go for gold.
James
https://www.sau.com.au/forums/topic/351201-powerfc-before-and-after-results/
its as good as the tuner
ie a remap done by an awesome tuner could make 200rwkw
a powerfc tune done by a poor tuner could make 50rwkw
its all down to the tuner, how well they tune it, and how quickly (this adds to cost)
a remap can make 500rwkw as can a powerfc as can a motec, as can a autotronic etc
no ecu is limited to a given power level, any one that says ECU XYZ will make more power, either cant tune it properly or is lying
if the car is tuned properly then there should be bugger all different in max rwkw between a well done remap and a powerfc tune
but back to your original question if it was just a basic remap ie remove speed cut and boost cut
for a typical r33 gtst it might make 170/180rwkw, with a powerfc it might make 200rwkw
again this assumptions on a basic tune and an r33, yours is a 32 so it would be different
surely it would come down to the person who tunes them...
eg.
I had a remap done by the god of remaps and then install a PFC tuned by fred at fred's mech repairs and there was little difference, I would not waste my money again in PFC
or
I had a remap done by fred's mech repairs and then install a PFC tuned by Unique Autosports and the difference was amazingly huge.... remaps suck ass
so real world experience will tell you stuff all IMO, personally PFC will shit all over a remap but Im looking at it from the point of view of future capability of the ECU as well...
I dont think anyone will be able to give you a rough power figure if they dont know your mods :P
Yeah I was a bit lazy wasn't I?
I've got 230.3 kW on 16 psi and the dyno sheet is below...
Dyno Sheet R32 GTS-T.pdf
Full RB20DET rebuild with upgraded rods and bearings
FMIC
Full turbo back exhaust with performance cat
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
Nistune Chip (on stock ecu)
Garrett GT2871R
Bosch 044
Exedy Super HD Clutch
I've just noticed Unigroup did the work (done before I bought the car)
Go hard
Edited by plan-b
Guest
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
