So you what do you think of this...
SAU Member: Kris..
rb20DET
HKS 25/35 turbo rebuilt by RotaMaster
JJR 38mm external watsgate
Supertech forged pistons 20thou oversized
ARP rod bolts
ARP head studs
Cometic metal head gasket
Cometic gasket kit
nissan oil pump
nissan water pump
nissan idler pully
nissan tensioner pulley
NDC bearing kit
HKS camshafts, 264/8.5mm
HKS cam gears
Gates timing belt
Tridon thermostat
crank was grub screwed, balanced and ground
balanced pistons
balanced and resized rods
block was decked, bored and honed
resurfaced head
valve grind
new valve stem seals
exhaust guides and ports cleaned up a bit
braided lines
GReddy returnflo front mount intercooler kit
Gkteck dump and front pipe
Blitz cat back
Splitfire coilpacks
JJR alloy radiator
z32 AFM
GTR injectors and resistor pack
Status remaped ECU
Walbro fuel pump
JJR oil cooler relocation kit
gutted cat
238rwkw @ 19psi
Me
Full RB20DET rebuild with upgraded rods and bearings (nothing forged as far as I know)
FMIC
Full turbo back exhaust with performance cat
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
Stock ECu remap
Garrett GT2871R
Bosch 044
Exedy Super HD Clutch
230.3rwkw @ 16psi Dyno Sheet R32 GTS-T.pdf
So the guy above threw 3 x as many mods into his 32 as me and only has 8 more rwkw and is running 3 psi more boost.
Can anyone explain this???
https://www.sau.com.au/forums/topic/351213-what-the/
Oh dude for crying out loud. Some reading before posting helps!
Every setup is different
Every dyno is different
Every tune is different
Every persons location is different (and this climate can be a factor in tunes)
You want any more possibilities?
Dyno results are a good guide, but to split hairs over 8rwkw is pointless.
If the dyno he is on, reads 10rwkw low, and yours reads 10rwkw high, then all of a sudden its 28rwkw.
You'll NEVER KNOW.
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5635828
Well that turbo would be prety close to being maxed out so its no matter what you do youll be struggling to go over with a 2535. At the end of the day you can have a full built motor with everthing you could possibly want on it and what would happen if you put a stock turbo? You wont make power.
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5635838
Different turbos, different tuner, different dyno.. unsure but his could make alot more power if the boost is wound up more.
also he seems to have done it the right way to make it all last and you seem to have the best turbo for your power range..
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5635839
You'll NEVER KNOW.
So why do we compare tunes then? If everything is subject to error/accuracy issues.
Why do you have a power thread to compare tunes? Why don't we tell everyone to do exactly the same mods and use exactly the same dyno at exactly the same temperature at exactly the same altitude at exactly the same geographic position at exactly the sime time of day.
Way to put a dampener on my day nismoid.
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5635845
SAU Member: Kris..
rb20DET
HKS cam gears
Blitz cat back
Splitfire coilpacks
JJR alloy radiator
z32 AFM
Status remaped ECU
Walbro fuel pump
238rwkw @ 19psi
Me
FMIC
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
Stock ECu remap
Garrett GT2871R
Bosch 044
i just removed the things that wouldnt effect overall power. he has 2 more mods then you. i could simplify the engine work by grouping it under "rebuilt engine" and im pretty sure it will be the same.
you pretty much have the same amount/type of mods but he is pulling more power.
peace out.
Edited by SECURITY
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5636257
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
