Up for sale is my R33 which I have owned since the end of october 2010. It has had a full respray GTR gunmetal grey on the 28/12/10. Has been recently serviced using top quality products. Air conditioner works excellent very cold.
Car will come with:
Heavy duty clutch,
Trust front mount intercooler,
3.5 inch 5zigen cat back exhaust
series 2 front bumper (I have the indicator inserts)
Ducktail spoiler,
Mushroom air filter,
Tien Super Street coilovers,
Tomei brake upgrade,
Custom split dump with screamer pipe (sounds awesome),
Boost controller,
New battery,
Turbo timer,
Original skyline floormats,
JVC headunit,
Alpine type R speakers
Only Bad Points Are:
Drivers side window is stuck up (pretty sure its just the regulator, will be getting it fixed before i sell it)
Just got a defect for pod air filter & blow off valve, i have already put a stock blow off valve on and fitted the stock airbox so all that will need to be done is for it to be taken to mechanics to get a certificate that its been changed and then have the certificate taken to vicroads. If it is an interstate buyer they will not have to worry about any of that.
Has Long rego till August 2011 For any more questions feel free to call or text me on 0433367570 anytime.
Will swap for V8 lemme know what you have
https://www.sau.com.au/forums/topic/351223-fsswaps-1993-r33-skyline/
sorry mate, im looking for $10,000, it has 109xxxkms on the clock, and im located in sydenham, victoria but will travel if buyer is 100% keen.
bump to the top! will swap for VP-VS SS, VS-WH Statesmen or Caprice V8, VR or VS Clubby, VR or VS Senator. but will consider all offers.
Edited by ROC-HRD
  • 2 months later...
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
