I just removed mine and literally noticed no difference? is it a tiny difference that you hardly notice? couldn't even see the vacuum meter change. i know it's not a great means of measuring boost but the maximum it ever gets is 350 mm of mercury (hg) i thought it would boost much harder? but still pretty much exactly the same? anything else i was supposed to do? what is the electrical wiring to the PCM?
post-70516-0-82030500-1295596272_thumb.jpgpost-70516-0-29469700-1295596298_thumb.jpgpost-70516-0-11304700-1295596309_thumb.jpg
Edited by Samuel Leonard
https://www.sau.com.au/forums/topic/351226-r32-gt-r-factory-boost-restriction/
Are you using a boost controller already?
not that i am aware of. car's got a dyno sheet stating it puts down 180 kilowatts. i'm an apprentice mechanic and i've had a good look around the engine bay and can't see anything? does this restriction usually make a pretty big difference?
an r32 gtr with restrictor out should boost 14.7 psi with full exhaust
well i definitely don't get anywhere near this. not even sure if it'd be getting over 8. it's in bar so it's not easy to tell. but 14 psi would be near the 750mm of mercury on the standard vaacuum meter and it's still at 350. i'm fairly confident it made no difference at all...
  • 2 months later...
Hey dude, did you ever find the answer to this? I have exactly the same situ except mine boosts just above the mark between 0 and +7 on the boost gauge. So slightly more boost than you according to the gauge but it didnt change when I removed my boost restrictor. Again no aftermarket boost control.
  • 4 weeks later...
mine was an easy fix. there are 2 restrictors, not just one in the line with the yellow band, but one in the other line to the PCM. it changed mine from .55 bar to .75 bar. .75 is just above the 350mm mercury line on the standard vacuum meter/boost meter.i'd estimate 500 to 550mm mercury.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
