First time i've wrote a build up thread so i here i go
bought an r32 gtr with blown turbos after having many skylines aim is to build a street car with good power 350kw at all the wheels
and to mainly do it all my self with sum help from mates except engine build
its been 18 months since i bought the car still have not driven my gtr other then towed around the front yard to another shed.
pulled turbos off and of course turbo was seized so new turbos bought garrett 2860-5, but end up selling them and got a twin td05 18g high mount kit with 50mm hks gate.
test fitted
then i though better check what was in this engine, it had cams 264 9.25 bonus and ported head.
checked the oil pump drive not a pritty site so found a n1 vergin block and crank will use that, also found then engine had been taken out to 87.5 60 tho over.
also going to go extrenal oil pump with larger sump set up yet to buy.
sum of the upgrades so far
r33 brembo brakes painted red
braided brake lines
volk gtc 18x10+22 with 265x35
tein coil overs all round and few ajustable arms
buddy club race zorst
n1 head light and boot lip to keep the car looking stockish
hks gauges egt, boost, oil temp, water temp and oil pres
nismo twin plate clutch
nismo speedo clustor
greddy radiator
split fire coil packs
surge tank and 044 pumps
greddy fuel rail
so after seeing the oil pump drive thought may as well do it propley as well as the smell of the bearing shells
so did sum research what to buy and where
bits i have bought so far for the engine build
manly h bean rods with arp bolts
cp 86.5 pistons
tomei 1.5mm head gasket kit
os giken cam gears
tomei valve steam seals
tomei cam bolts
arp head and main bolts
tomei valve spings and retainers
n1 water pump
tomei over sized valves
have got most of the parts to have the engine built
its just the coin that holds u back
does not take much to spend so much
https://www.sau.com.au/forums/topic/351237-r32-gtr-bulid-sa/
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
