My RB20s is breaking tractions in every gear at 5800rpm.
Im making two hundred firty kilowatts at the wheels, running chopped springs and 10 degree neg cambers on the rear, my tires are below the indicators and hard as a cats head...any suggestions how can I stop this torqueless animal spinning the wheels, no one else I know with an RB20 has this problem, is mine one of these illusive factory 'freak' motors?
Thank god you got banned, youre a goose plan-b.
i actually got angry byt the end of his rb20 wheelspin @ 5800 thread.
this guy is a moron. he should not be armed with a set of car keys.
LMAOOOOOOO did he say this I didnt see it. There was another guy with a rb20 a while ago that had 215kw and was complaining about wheel spin through all 5 gears. Probably just clutch slipping for 5 gears lol.
Have a look through the wheelspin at 5700 thread. Try to find the first person to say a nasty comment.
It's him!
Aside from me asking if he was taking the piss, everyone was giving constructive answers. Then he just turns on everyone (inc Ash - lol)
I took an instant disliking to him from that point. He could be a nice kid but he needs to take a different approach to constructive criticism
you can get 300 cc out of 270cc injectors with an aftermarket fuel pressure reg so if you run 10 more fuel pressure regs it will make 500 hp easy
Oh ok. So if my maths is right:
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
    • I'm looking for a direct bolt on turbo upgrade for my 93 R33 GTST.  Anyone have experience with this Greddy T620Z turbo upgrade? I'd like to be able to run about 300hp to the rear wheels without putting too much strain on the turbo. I do daily drive the car.  Pretty stock car with basic bolt ons (exhaust outlet, down pipe, high flow cat and catback exhaust along with intake and FMIC).  I'l probably have a Haltech plug n play on the car before installing the turbo. https://www.greddy.com/products/turbo-upgrade-ecr33-er34-t620z-rb25-11520057   Also, any thought on this much boost on a 30 year old motor with 250,000KMs?  Engine feels/sounds strong for what it's worth.   Thanks you in advance!
