One way up the road, i got up to 9 on the knock meter. then, when i turned around and came back, it didnt change from 9. Thats why i said it had 0 knock.
Before "elite racing" mentioned that the number displayed is actually the level of knock, not the amount of knocks, i never actually knew that. So, its possible that it knocked along the way home and didnt go above 9. I should have switched the motor off after one way, to then see what happened on the way back, but i never knew how the knock counter worked.
I will do more testing tomorrow and see some results, as i will need to refil after the trip home so i will use BP to see if that works to check that possibility. I have booked a tune in for monday afternoon so if it isnt a petrol issue than i will see what the tuner can do.
Thanks guys :)
As Jonno said - it's just the peak.
If you set it to real-time monitor you will see the bar constantly moving.
IT honestly sounds like you don't really understand the basics of the PFC & Hand Controller :(
Ill teach him on monday. Dont think he has had the car too long
+1
On the drive back home, i left it with -2 degrees timing and it was ok. Got to like 14 or so in the whole 4 hours driving. Put BP ultimate in as i got home, then went for a 10km run. No abnormal knocking, only about 9 or so on the meter, with no timing changes. Going for another run later tonight see how it goes then.
Might have been a bad batch of fuel
That why i recommended running a different brand in it just for a test.
We have ahd a bit of dodgy fuel lately with all the rain, some places worse than others.
If it was me, may as well just go get a touch up tune as you never know how good or bad the previous tune is.
Try and find someone who will tune with engine mics attached to the block etc instead of relying on the oem knock sensors that are 10+ years old. I think there's a two different camps regarding this and one is that the oem/factory knock sensors are useless past much factory output and have aged and will give alot of false readings. Guilt toy mentioned he experimented with relying on factory knock sensors via pfc then using a k-mon (knock detection device) and tuning using the k-mon gave an extra 30rwkw or something and a fatter mid range.
With the pfc utilising the factory knock sensors...i've been told/read anything over 60 is bad and under it is kinda ok. No setup using the pfc/factory knock sensors will ever register no knock (i.e. you will always see knock values in the safe range of 0-40 or so). I guess you have to decide for yourself whether you'd be happy with a tune using the factory knock sensors or that k-mon thing etc.
A thing to be aware of is after getting a touch up tune, make sure the tuner is willing to go on the road quickly to check their tune in real life as sometimes a dyno tune with no knock will knock on the road/real life conditions due to differences from being on a dyno and on the road. I had this issue but didn't want to do a road tune so a quick touch up was applied to the touch up tune lol and it still knocked...pretty gay..
In the end i changed to different fuels and used the pfc hand controller to find the offending load cells and adjust as necessary.. this was kinda painful as i didn't have the fc datalogit program and relied soley on the hand controller. What i did was set the controller to display two values being knock and rpm then soon as i saw abnormal knock, i would back off then inspect the rpm point and go into the ignition maps and adjust as necessary. Then reset the display values (right arrow button) and repeat this process until WOT gave no more abnormal knock readings. Remember you will need to know your WOT map trace pattern first to do this procedure.
yes the standard knock sensors and pfc arent perfect and a k-mon or similar is better but aslong as the knock sensors are working and and the pfc isnt displaying high numbers of knock then the car isnt knocking. the standard knock sensors pick up a lot of other noise and high numbers arent always knock but they will almost always pick up actual knock. the reason guilt toy was able to wind in more timing (and therefore make more power) with the k-mon is because the stock knock sensors were falsely reading high levels of knock, with the k-mon he was able to find the real safe limit. so the standard setup isnt ideal, but its fairly safe.
Exactly. The standard knock sensors are too sensitive. Therefor tuning with these might not net the extra kw but atleast there will be a larger safety margin.
I am roadtuning his car tonight so i will post up what i find. He also wants to up the boost from stock
Ok fitted a 3inch dump and front pipe. Still has 2.5inch catco cat.
Then went for a drive to check the tune, had a lean hole in the tune under WOT around peak torque which was causing an increase in the knock count. After richening up where needed the knock didnt go above 9, have
increased timing slightly under full throttle and still max knock was 14.
When Lachlan gets a 3 inch high flow cat i will recheck and youch up the mixtures.
His avcr wont respond to any changes to the boost level. Have tried initialising it. Learning on and off etc. Checked the install and looks ok. The solenoid is clicking when boosting as it should
If anyone has any input on thatplease sharr
Anyone know about this? Its frustrating me. It all seems connected fine, but wont change anything to do with my boost. Cranked it up to 16psi and still only does stock.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
