I just purchased another S13 less than two weeks ago, only to realise the chassis is bent, so I'm stripping this S13. It's red in colour. I still have parts from my other S13, so refer to the previous thread if you want to see what's left with the first one.
If you would like to purchase anything from the list below, don't waste my time. You'll need to organise it with me, and put a deposit down, otherwise it won't be removed from my car. I have not had any problems with people making a deposit first so far, and everyone seems happy. Check my profile for comments from buyers about their buying experience with me.
LOCATED IN CANBERRA, ACT - **I CAN POST ANYTHING TO YOU FOR CHEAP VIA COURIER WITH A TRACKING NUMBER**
---------PM ME, CALL OR SMS ME ON 0411 086 883---------
SR20DET motor with Tomei rocker arm stoppers, sard injectors, nismo adjustable fuel regulator, roughly 60 000km's, and gearbox good compression on every cylinder (around the 160 mark on each one) with no turbo, or manifold-$2200
Haltech E6X ECU and as new wiring harness-$1000
GKTECH S13 bash plate (stops your sump from getting damaged)-$120
HKS EVC Boost controller with wiring harness, etc-$200
HKS Turbo timer with wiring loom, etc-$70
Quick release steering wheel with boss kit, etc-$120
S13 space saver (spare wheel from boot looks unused)-$30
Reinforcement bar for the front has been modified to fit front mount-$50
HKS BOV painted black-$80
Engine damper-$50
Cusco adjustable strut brace-$130
Oil catch can-$40
Drift wing with all mounts, and bolts-$100
Complete vertex (I think) bodykit-$400
Standard tail lights-$50
Walbro fuel pump and cradle-$160
Alloy overflow bottle-$80
Bonnet hinges-$25
Bonnet cable-$20
Throttle (accelerator) cable-$30
Headlight brackets-$40 for the pair
Fuel cap lid-$10
Front drivers side fender straight as pretty clean with barely no scratches-$100
Passenger side fender got a small dent in it-$40
Sunroof motor with glass, and cover in perfect condition-$150
Windscreen wiper motor-$25
R180 4.3:1 ratio diff with 6 bolt stub axles-$50
Hybrid limited edition front mount intercooler with all piping painted black, and clamps in perfect condition-$550
Nismo 2 way with 5 bolts stub axles LSD-$800
Kaaz 2 way with 5 bolt stub axles LSD-$800
J series (square headlights)-$300
Ganadoor style mirrors with cool led indicators that you can wire up as blue, orange, or something else-$70
S13 passenger front fender few small dents-$50
Silvia standard grill painted black, and "Silvia" letters have been cut out-$20
S13 Square (J series) headlights with clear covers perfect condition-$400
Window regulators: Drivers side-$60 Passenger side-$50
Window switches (No chips or cracks perfect condition)-Drivers side-$80 Passenger side-$60
Drivers side glass-$60
Passenger side glass-$45
SR20DET manual non-abs HICAS Tailshaft-$100
Front SR20DET rotors and calipers (have heaps of meat on them)-$150
Back calipers and rotors-$120
5 bolts drive shafts: $80 for the pair
S13 boot with few small holes for a spoiler perfect condition-$70
S13 bonnet in good condition with holes drilled for bonnet pins and painted matte black-$200
Doors without regulators and trim in awesome condition-$100 each
INTERIOR PARTS:
Dash with no cracks, but holes drilled for four 60mm gauges-$140
Nismo 280km/h speedo with only roughly 65000km's and blue LED lights-$350
Standard S13 cluster with white dials roughly 144000km's-$60
Door trims in perfect condition with material-$50 each
Pair genuine Recaro seats in good condition with rails to suit 180sx, S13, S14, or S15-$700
Cluster surround with all switches and air vents-$30
Centre console-$50
Stereo surround-$20
Sony stereo-$80
Greddy green gauges with sensors, wiring loom, etc-$150 each
Digital climate control with loom (no scratches)-$150
Scuff plates-$30 pair
Door seal rubbers-$70 pair
Boot seal strips (stop water running into your boot)-$20
Interior carpet-$40
Door trims-$50 each
Black centre console with ashtray, power mirror switch, etc-$40
Sunvisors-Both for $20
Front seatbelts (they extend and retract perfectly)-$80
Rear seatbelts (they extend and retract perfectly)-$70
Roof handle support (that you hold onto when getting in the car sometimes)-$10
Rear seats-$40
Rear plastics that sit behind the back seat-$25 for all
Steering wheel shroud cover(sits behind the steering wheel to hide the wiring)-$25
Map light-$20
Fuse cover for drivers side interior fuses-$10
Heal rest for your foot-$10
Rear view mirror-$15
Rear interior light-$15
Drivers side under steering wheel kick panel-$20
Drivers side kick panel-$20
Passenger side kick panel (that the ECU sits behind)-$20
Glove box with hinges-$30
Pillars-$20 each
Turbo timer with complete wiring harness and it displays batter voltage, etc-$40
Hey mate, any idea if the steering wheel + boss kit would fit an R31 skyline? Also, do you have any front suspension? Any parts at all, struts or lower control arms etc?
I am located in Canberra also.
Thanks.
Sorry, the Nismo diff has been sold. I've tried to update this thread but it won't let me. I've tried everything damn. Does anyone know? Also, here's a picture of one of the Recaro seats.
got a str8 registered shell you could put it all in? $200 :)
http://cgi.ebay.com....=item3f06ffdb1b
Or not, so don't post your stuff in my thread mate!
    • I am so glad I've been stepping away from the internet more and more so I don't know what "Just Rolled In" is. And no, I'm not googling it, or clicking any links you lot provide.   Second, Prank, pretty much, that silver stuff, wrap all of one section in a new colour. I recommend NOT using anything glossy, go for matte or flat colours. Current work car I'm driving has so many shiney chrome bits and gloss black bits that at certain points of the day I feel it would be easier to drive blind... So much glare in the eyes!
    • You might as well just vagazzle it, like the dumb bitches on Just Rolled In.
    • I thought not. R32s certainly weren't. R33s definitely could have been, but I thought they had much the same gear in them as the 32s. I could be wrong. I had my r32 converted to R143A before I put the Neo motor (and its R34 compressor) into it. So I didn't even really consider the original refrigerant for the 34's compressor. Seeing as the very idea of "conversion" means that it doesn't really matter anyway. What it would really come down to, in the car in question, is what ports are on the lines and if they are R12 or R143A ports. And the little bit of work required to convert them and clean the system out of the old juice.
    • Bro, its a series 2. Point made. BTW, I love the line "I have been advised this car is worth $50,000". I love that. My dog just told me my E39 is worth $100k. Send your offers.
