In excellent condition, fantastic to drive, real head turner. in South Australia
Colour: Grey
Kilometers: 166,531
Wheels: 17'' light performance mags
Body: Type X front body kit and Sunroof.
Exhaust: 3'' cat-back exhaust system with extractors
Engine:
  • K&N pod filter
  • Single turbo
  • Blow off Valvue (BOV)
  • ApexI turbo timer (hasn't been installed)
  • Imboliser
Interior: For a 21 year old car it is in excellent condition as it has been very well maintained over the years. No cracks on dash, soundstream amp, pioneer 6x9 speakers, pioneer deck and three custom made gauges hich have been fitted. Always garaged and wash on a regular bases and recently added tinted windows. Asking for $7,000 ONO and even may consider swaps just tell me what you got
Feel free to contact me if you have any further enquires. 0421 780 171
Edited by faesal
https://www.sau.com.au/forums/topic/351327-cheap-180sx-for-sale/
Colour: Grey
Kilometers: 166,531
Engine:
  • K&N pod filter
  • Single turbo
  • Imboliser
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
