  • Replies 49
AWD Turbo Challenge - Round 4 Results
pdf-med.gifMulticlub Hillclimb 2 OVERALL RESULTS
pdf-med.gifAWD Turbo Challenge ROUND 4 RESULTS
Congratulations Andrew Bartlett (Open), Michael Willis (Modified) & Craig Van Diemen (Club) for winning their respective classes.
OPEN WINNER:
MODIFIED WINNER:
CLUB WINNER:
Willall have four GTRs out there racing in the Time Attack 3 on Monday for those that want to watch
Willall R35 GTR WR600 - Keir Wilson
Willall R35 GTR WR450 - 'Carbon King' Sebastian Lip
Willall RH9 R32 GTR - Kurt Wilson
FBRE/Willall R32 GTR - Our very own Blue32
Quite a lineup, thats over 2000awkw between the four of them or an average per car of over 500awkw..... :cheers:
Note: No Disney Dynos involved :domokun:
What's wrong? 4000 laminated confirmed corrected printed calibrated killa watts at the wheels in Disney Land not good enough for ya?? Cheapest perfomance upgrade I did was spend $60 on a DD dyno run.....
AWD Turbo Challenge - Round 5 Results
pdf-med.gifAutosport Time Attack Round 3 OFFICIAL RESULTS
pdf-med.gifAWD Turbo Challenge ROUND 5 RESULTS
Congratulations Sebastian Lip (Open), Dryden MacDonald (Modified) & Damien Hirst (Club) for winning their respective classes.
OPEN WINNER:
MODIFIED WINNER:
CLUB WINNER:
Edited by Catford
AWD Turbo Challenge - Round 7
Autosport Time Attack Round 4
3rd October 2011 (Monday Public Holiday)
Mallala Motor Sport Park
pdf-med.gifTime Attack Round 4 2011 ENTRY FORM - NOW AVAILABLE
pdf-med.gifTime Attack Round 4 2011 SUPP REGS - NOW AVAILABLE
AWD Turbo Challenge - Round 9
Legend of the Lakes Hillclimb
4th - 6th November 2011
Mount Gambier
pdf-med.gifLegend of the Lakes Hillclimb ENTRY FORM - NOW AVAILABLE!
pdf-med.gifLegend of the Lakes Hillclimb SUPP REGS - NOW AVAILABLE!
Edited by Catford
  • 3 weeks later...
Good one, you will have fun
I am surprised there arent more entries from here - Collingrove is one of those things like Coopers Beer and rancid old Pie Floaters that simply must be done at some stage if you are a South Aussie. Very rich in Motorsport heritage and tradition that place :)
  • 1 month later...
AWD Turbo Challenge - Round 6 Results
pdf-med.gifMulticlub Hillclimb 3 OVERALL RESULTS
pdf-med.gifAWD Turbo Challenge ROUND 6 RESULTS
Congratulations Martin Donnon (Open), Artur Niedzwiecki (Modified) & Craig Van Diemen (Club) for winning their respective classes.
OPEN WINNER:
MODIFIED WINNER:
CLUB WINNER:
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
