i've just noticed on the rb25det there are an extra line from the head running to the block. what could these be used for? & what do i do with it as the rb30 block doesn't have a tapped hole on the block to fit it...
here's a pic of the rb25det block with the line>>
& here's the rb30 block that doesn't have a tapped hole to fit the line>>
if he is going aftermarket cams then no need for it really. nothing a good set of cams and adjustable gears and some dyno time wont fix in regard to any VCT losses.
question tho.. any reasons the neo's dont have VCT feeds on them? is it because they are solid lifters so less oil in head.
That is an oil drain, and nothing to do with VCT. It's on the wrong cam to start with for VCT!
Keep it connected, get it fitted to run into the sump directly.
Get the VCT connected. HUGE benefits.
T that line into the turbo oil return.
theres a thread on here for an internal vct feed, if you already have the tools then its free to do and doesnt take long at all, very worth it.
dammit. im going to have to hook this up in my 30.
im going to do the internal VCT feed then widen my oil drains in the head. since the oil restrictors are in the block will that external oil drain make any real difference?
yeah i'm just going to T it into the turbo oil drain.
not keeping the VCT either, i'm guessing all i have to do is block the oil feed off in the head & thats it? anything else i have to do?
it wont stuff the head or anything blocking the VCT off will it???
    • Hey guys I have a 2001 Nissan stagea vq25det, I don't have any engine lights and not really any issues running but I was curious to see if I could use my obd II scanner to find anything that was hidden and I plugged my scanner in and it just said "Low voltage cannot scan" does anyone know how to fix this or what this could be?
    • Sadly we have something in common, our Skyline's like blowing up electrically 馃槩
    • So, no videos, but, the FAB9 Elite manifold and 68mm Bosch throttle bodies are in stock, but, not the rear part of the air box The FAB9 rear airbox thingie is made with a 3" intake pipe, to suit the 3" intake pipe size of a 68mm throttle body  When they get some more in stock is currently unknown as I'm waiting for FAB9 to reply with a ETA on resupply, my assumption is they outsource their plastic printing stuff to "china", and with the current "tariff war" going on in 'Merica it could be on hold for an undisclosed time Should I pull the pin on the Intake and throttle body, and wait for the airbox?????, that's what I'm thinking... 1. Would the standard 2.75" OEM intake on the air box really be that much of a restriction compared to the 3" naturally aspirated?????? 2. If I don't get the 3" FAB9 airbox fitted at the same time as the intake and throttle body will it need a retune, when/if it eventually turns up?????? As I'm impulsive, to a fault, decisions will be made within....."what's the time now"???....let's say 12 hours......LOL
    • yeah its just so expensive nowadays and its easy to lose motivation very quickly when you start adding up the costs. I acquired the car from a collector in Melbourne and was lucky to get the opportunity to buy something already completed.  I looked at a proper resto and your paying over 300-400K for a proper one (nut and bolt) so this one to me seemed like a much better option! Car is in private storage and for serious buyers, welcome to come see it/drive it in person (photos don't do it justice).
