Leaving the country, so my Zed has to go. Have recent service reports from PZP to confirm that the car is mechanically perfect. I have made this Zed as reliable as possible with ALL maintenance done, so the only extra money you will need to spend is on mods.
Model: Nissan Z32 300ZX
Year: 1989
Body (2+0/2+2): 2+2
Colour: Cherry Red Pearl
Engine (Turbo/NA): TT
Transmission (MT/AT): Automatic Cima gearbox, modified valve bodies
Interior (Cloth/Leather): Tweed, front seats are Velour
Odometer: 156,xxx genuine
Price: $10,000 ono
Contact Details: Through PM or 0412 065 928
Comments:
Car has been taken care of to the full extent of my capabilities and has been serviced 3 times a year by PZP. I have had all preventative maintenance done, previous owner (the one who imported it) had a plenum pull done 4 years ago and i just had another complete plenum pull and bypass done less than 15,000km's ago by PZP. I have owned this Zed since February 2009 and have done a little over 30,000km's since then. I have all paperwork and full maintenance/service history from the moment this car arrived in Australia.
This zed has never seen a racetrack or a drag strip, nor has it been dyno'd. It has been used as a daily, however it was only driven 3 times a week. Intake pipes and vacuum hoses have just been replaced with silicone ones.
Aftermarket parts/work:
- Nissan Cima gearbox with modified valve bodies (aka. a "shift kit")
- KYB AGX shocks with aftermarket coil-over kit and springs (lowered but legal, installed less than 10,000 km's ago)
- 17" EOS rims, slight paint flake in some areas, but no gutter rash at all (i have never hit a curb), tires have at least 85% tread
- Apexi Pod filter
- PZP front upper camber arms
- Hardrace Tensions rods and brace fitted less than 5,000km's ago
- Pro-F "Sheepdog" BOV's
- Kenwood headunit with 3 rca pre-outs
- 2 channel amp with 6x4 kenwoods in front and 4x4 kenwoods in rear.
- Aftermarket transmission cooler
- Npower front strut brace
- Complete plenum pull and bypass done (Twice, both times by actual Zed workshops)
- 100k servicing done 30,000k's ago
- New thermostat put in less than 5,000k's ago
- New spark plugs installed less than 5,000 k's ago
- Custom made 1-piece tail-shaft done by previous owner
- Rear spoiler is a fiberglass mold of the stock foam spoiler
- Central locking/alarm/immobilizer/turbo timer
- Manual boost controller
- Radiator was just replaced 5,000k's ago with refurbished unit
Stock Options
Just a few stock options that came with the car:
- Front bar is a rare Impul 932S, the car was purchased brand-new from Impul Japan with this front bar on it.
- Stock mud flaps, both front and rear
- Cargo-blind is still intact and working perfectly
- Full set of stock jack + tire wrench + tire wedges
- Includes spare wheel in excellent condition, it's been used so i can vouch that it works perfectly
Minor Issues
The only problems with the car are extremely minor and/or cosmetic:
- Clear coat from the side mirrors is mostly gone
- Have a slight dent on the drivers side door, but that will be fixed before i sell it
- Heater core has been bypassed
- Air-conditioning has gas and works fine, however it had a bad solenoid which was causing rough idle, so it has been disconnected. Extremely easy fix and like i said the A/C itself works fine, i just simply do not use air conditioning so i had no reason to fix the issue.
- Passenger side windscreen cowl cracking, extremely common issue, plastic just cracking from the battery fumes.
Pics:
http://img.photobuck...shwin/Front.jpg
http://img.photobuck...08102010034.jpg
http://img.photobuck...n/moto_0336.jpg
http://img.photobuck...n/moto_0338.jpg
http://img.photobuck...20012011101.jpg
http://img.photobuck...20012011102.jpg
http://img.photobuck...18082010321.jpg
http://img.photobuck...18082010320.jpg
http://img.photobuck...18082010319.jpg
I'll also be giving whatever Zed related stuff i still have to the buyer. This includes a set of stock wheels + tires, a few hoses and pipes, random bottles of fluids, the socket set and tools i keep in the boot, stock BOSE sound system that i removed (inc disc stacker), and the rear wiper + motor + weights that i've removed (still works perfectly).
https://www.sau.com.au/forums/topic/351385-1989-z32-j-spec-auto-tt/
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
