Hi all
I am finally approaching R32 GTR ownership with test drives and vehicle inspections arranged over the coming fortnight. Having returned to the SAU forums (after approx 4 years absence), I have been reading a lot, again, about HICAS on the R32 GTR. It seems to me the vast majority of R32 GTR drivers prefer their cars without it.
So my question is: when the R32 GTR begun its domination of Australian Touring Car Championships at the hands of Mark Skaife and Jim Richards, did that particular variant of R32 GTR have HICAS???
For the record, I am currently looking a 1994 R32 GTR recently imported to Australia from Japan with approx 90,000 kms on the clock.
BunsenBurna
Hi all
BunsenBurna
if its 90K, which is very odd number :)
you better have the 100K service done on it ASAP, in case you buy it
otherwise might regret big time
The R32 was homologated both with and without Hicas, after testing both options it was left of race cars, mine was locked when I bought the car, and I would love to know what it's like, but all report are I would just waste time getting it to work only to lock it again. Pretty sure every r32 GTR had it from the factory though
maclarenf1 - why is 90k such an odd number? I'm certainly mindful of the big 100k service. I am trying to be very thorough pre purchase of this vehicle.
Thank you iplen for the info. We'll see how I go with HICAS!
not to put a damper on things:
90k. now the last one of those cars was built in 94. that is currently 17 yrs (assuming a Jan94 build) so 5300 km/yr as a round number. if that car comes up at a cheap price I would suspect something is amiss with it. if its a genuine example then the owner is going to want a LOT for it. they are becoming collectors items and the japanese are well aware of it.
re hicas: see the post a few back. racecars didn't have it the road cars (or every one I have been under) did.
once I get mine finished it will have it functioning as well.
its not noticeable until you get up to speed and then the car turns in a bit quicker :)
What sort of money would you consider a lot? I'm certainly not paying $45,000 - $53,000 (like the fine Aus delivered examples sold as part of a Sydney auction recently).
I am being overly optimistic that the kms are genuine, call it wishful thinking amongst other things. But I am having the car thoroughly inspected and I am expecting to part with a pretty penny.
Fred Gibson removed the HICAS from the race cars because it had the nasty habit of turning the car around if you backed off halfway around a corner. Not an ideal situation on the racetrack.
NEVER believe the odometer of a car delivered from Japan.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
