Hi all
I am finally approaching R32 GTR ownership with test drives and vehicle inspections arranged over the coming fortnight. Having returned to the SAU forums (after approx 4 years absence), I have been reading a lot, again, about HICAS on the R32 GTR. It seems to me the vast majority of R32 GTR drivers prefer their cars without it.
So my question is: when the R32 GTR begun its domination of Australian Touring Car Championships at the hands of Mark Skaife and Jim Richards, did that particular variant of R32 GTR have HICAS???
For the record, I am currently looking a 1994 R32 GTR recently imported to Australia from Japan with approx 90,000 kms on the clock.
BunsenBurna
Hi all
BunsenBurna
if its 90K, which is very odd number :)
you better have the 100K service done on it ASAP, in case you buy it
otherwise might regret big time
The R32 was homologated both with and without Hicas, after testing both options it was left of race cars, mine was locked when I bought the car, and I would love to know what it's like, but all report are I would just waste time getting it to work only to lock it again. Pretty sure every r32 GTR had it from the factory though
maclarenf1 - why is 90k such an odd number? I'm certainly mindful of the big 100k service. I am trying to be very thorough pre purchase of this vehicle.
Thank you iplen for the info. We'll see how I go with HICAS!
not to put a damper on things:
90k. now the last one of those cars was built in 94. that is currently 17 yrs (assuming a Jan94 build) so 5300 km/yr as a round number. if that car comes up at a cheap price I would suspect something is amiss with it. if its a genuine example then the owner is going to want a LOT for it. they are becoming collectors items and the japanese are well aware of it.
re hicas: see the post a few back. racecars didn't have it the road cars (or every one I have been under) did.
once I get mine finished it will have it functioning as well.
its not noticeable until you get up to speed and then the car turns in a bit quicker :)
What sort of money would you consider a lot? I'm certainly not paying $45,000 - $53,000 (like the fine Aus delivered examples sold as part of a Sydney auction recently).
I am being overly optimistic that the kms are genuine, call it wishful thinking amongst other things. But I am having the car thoroughly inspected and I am expecting to part with a pretty penny.
Fred Gibson removed the HICAS from the race cars because it had the nasty habit of turning the car around if you backed off halfway around a corner. Not an ideal situation on the racetrack.
NEVER believe the odometer of a car delivered from Japan.
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
