  • 11 months later...
  • Replies 81
Posted Images
please clarify
i have been told from numerouse mag wheel dealers that 9.5 on the stagea is to wide and will creat issues
i am looking at dropping my m35 on some BC BR coilovers and running big break kits witch mean ill be running 19 inch mags
so what size width mags can i get with 19s? that i can use on the stagea that wont rub 8.5s or 9s
if i get a spacer does that mean i can go wider ?
with offset does a - or a + offset mean a bigger dish etc
or do u guys recomend 18s for the stagea
Most Aussie tyre shops only sell +40 as that's all they can get. Speedy, ROH and such all do crap offsets.
They're starting to get better as more Falcoon & Crummydore owners buy staggered sets for their bombs, and they're getting a bit more savvy to offset & caliper clearance too.
Edited by Daleo
I tried some 19*9.5 +38 on mine with 245/35/19 tyres and they fit perfectly and could even have gone wider on the rear i.e. lower offset.
Do you have any pics? Was there any suspension work done to it? Any rubbing on full lock?
I've mentioned on another thread that I've found some 19x8x5+35 or 19x9.5+40 from Avant Garde (Model M368) that would suit the M35 really nicely.
^ Agree.
I think that with the Nismo suspension I could fit 19x9.5 with a +35 offset and have 3mm clearance. Not enough for my liking.
Having said that, I just picked up a set of Buddy Club P1 Racing 2's which are 19x9 with a +45. Not ideal so will have to probably run 10mm spacers although I don't know how they will sit with the Autech suspension.
If all else fails, they came with 30mm spacers :P
No pics sorry I didn't end up buying them. They were Buddy Club P1's or something. I can't remember how much clearance but it wasn't much and they never scraped anywhere when I drove on them. I have factory bilstein suspension and my car is quite low which would have helped as well. Still, I would have bought them if they were in better condition as I didn't think the clearance was an issue but maybe the bilstein stuff is different to the Nismo or other factory suspension, I don't know.
^ Agree.
I
Now that I have nisom suspension im looking at wheels. what would these offsets be like
Fronts - 19x8.5 +25
Rears - 19x9.5 +35?? Kinda new to the size and offset thing.
Fronts - 19x8.5 +25
Will you be running in RWD only? Staggered sizes won't work with AWD.
I reckon the 19x8.5 + 25 would be better for piece of mind regarding possible clearance issues.
The 19x9.5's were a +40 with a 5mm spacer. They fit and cleared the suspension, but not by much.
No spacers needed with this size?
Running 18x9+20 with 235/40/18
Car stits 345mm from centre of wheel to top of wheel arch ,
On bc coilovers
No rubbing at all , no guard rolling needed
Just thought I would share for anyone in the near future
What's your camber settings?
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
