Up for sale is my 1993 R32 GTR. Beautiful car for daily driving or weekend touring. Car has been serviced every 5000kms and all fluids has been replaced a month ago.
Car is straight and has NO rust at all. Car needs to be seen in the flesh to be appreciated.
Only reason for sale is that I have bought another car, so this one needs to go as I can not keep both. Not interested in swaps.
Car was tuned at Unigroup about a month a go and made a very healthy 247kw with 14psi.
Mods include:
Rego til April 2011 and car has 94,000kms.
Apexi Power FC with Hand Controller
Grex Oil Cooler and oil filter relocation kit
Nismo Fuel Pressure Regulator
Blitz dual BOV's
HKS Air filers
Nismo N1 Headlights
Brembo front brakes
Nismo front strut brace
Cusco rear strut brace
Cusco caster arms
Underbody bracing
Kakimoto exhaust
Hi-Flo Cat
JIC Coilovers
18 x 9.5 +12 Rays TE37 with Kumho 265/35/18
ARC Intercooler
Blitz dual SBC Boost Controller
Blitz Turbo Timer
M’s Torque Split Controller
Hicas Lock bar
Walbro Fuel Pump
Im after $23,000 ONO. I will sell the car cheaper if buyer does not want the rims.
If interested you can contract me on 0410 336 988 or PM.
Thanks for looking.
https://www.sau.com.au/forums/topic/351398-syd-r32-gtr/
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
