Hey guys
I have a V35 sedan 250 GT
and I just want to lower my car if possible, I tried Repco and Pedders, but they dont even know what V35 is.
I was wondering if there is a car which has identical springs as V35?
And I DONT want to do dodgy stuff how people cut springs n stuff.
In the future I will order Coilover form Japan, but for now, I need Lowerd springs.
https://www.sau.com.au/forums/topic/351437-how-to-lower-v35-sedan/
yeap + 1 on the 350Z springs it loweres it about 1 inch to 1.5 . i got mine very cheap from a local mechanic cus he put coilovers for one of his customers and the guy didnt want to keep his old shocks and springs so i gave the mechanic $50 and got me a set of prety decent springs.
and best thing about that no decrease in ride comfort or scrape on speed bumbps
  • Like 1
350z springs are not the SAME as V35 sedan otherwise there would be no point in recommending them to you. They are however compatible and are slightly shorter than V35 springs hence lowering your car by approx 1inch.
Check my topics....I have the complete set of springs and shocks from a 350z in my V35 sedan. A few other members have done the same with good results.
I have v35 gt-8 and just been lowered .. King Springs sent me a wrong ones ( too low ) then they have to make new sets just for my car .. I suggest you contact them and have to ask for the v35 sedan ... the new springs set the car nicely and fitted 17x8,5 and 17x9.5
Ask for Kris Tarrant as he is the person that took my order
I have a set of t2000 titanium springs under my v35, its too low. I need a set of 350 springs, any ideas?
Same springs as I had on my 300GT before the change to Z springs. Low is an understatement.
Now just need to sort some camber issues. :(
Keep an eye on all Nissan forums for Z spring.
  • 1 month later...
from what i read on teh g35driver forum, my understanding was you need to use the 350 sturts/shocks along with the springs.. not just the springs with the 35 struts/shock.. due to travel lengths and blowing the ass out of the 35 shocks over time from being to low.
Edited by GeNOS
has anyone played with shock spring combos? im wondering if the 350z setup stiffness is due to spring or shock..... am considering putting the Z springs with the V shocks to see if it loses a bit of its rigidity. as it is, the Z shocks and springs compress less than an inch max under load
anyone have some springs they want to sell?
see my first post above
i really want to know if people have had personal experience rather than word of mouth.....
plenty of people say bmws are too expensive to own and fix, but i proved they were cheaper than holdens with a bit of know how
From personal & current experience I have to disagree with your statement saying the 350z shock and spring combo is like riding on bumpstops.
I have driven on stock suspension, aftermarket coilovers and have fitted the 350z shock and spring combo to both my V35 sedans 300GT and 350GT.
The 350z combo rates the best amongst all the above in terms of balancing comfort and handling. Yes they are a bit firmer than factory suspension but overall still gives you similar ride quality without sacrificing much in terms of comfort. There is also the added bonus of increased handling and reducing body roll.
My wife drives the V now taking two kids in the backseat and she has never complained once about the suspension qualities, infact I doubt she even noticed when I switched from factory to Z suspension :)
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
