the 350z shocks and springs in my 250gt sedan exactly replicates the "driving on bumpstops" sensation, this is in comparison to a previous car i owned which infact was on the bumpstops.
it is also important to note that i roll on 235-35-19's..... so there is no sidewall to absorb bumps either
it is shaking the crap out of my interior. have noticed a few new constant squeaks and rattles including centre console, left a-pillar and parcel shelf from the first drive with Zs fitted. most of the bouncing is now just me being thrown out of the drivers seat, and items in my boot getting airborne. and im no hoon, i only drive at 55. it is quite simply horrible
Edited by Trick V35
i really want to know if people have had personal experience rather than word of mouth.....
plenty of people say bmws are too expensive to own and fix, but i proved they were cheaper than holdens with a bit of know how
its not word of mouth.. its personal experience i read from the guys on g35driver forum
Might find you scored the track spec 350z suspension? It is firmer than the standard 350z stuff. Either that or get rid of the 350z springs and buy some eibachs they are the best springs for the money around imo.
Im running 350z track shocks with aftermarket springs and the ride is o.k its firm but not ridiculous.
What you are describing shouldn't be the case...I'm riding on 235/40/19. Either your shocks are dead or as explained above you got the track version.
aaaaaah! theres something ive overlooked! time to do some part number research. if thats the case, i'll be looking for non-track items. they definitely feel as though they would be more at home on a smooth racetrack than roads with manhole covers and speedhumps.
Edited by Trick V35
Research suggests I have the early 350Z setup with the stiffer rate rear springs. The later 350Z's have same fronts but softer rears, which would be better IMO.
  • 1 month later...
  • 2 years later...
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
