how much power are you planning on making? and on which fuel?
I would be really happy to get about 300kw at the wheels and be running premium fuel. My motor has been fully rebuilt, i have adjustable timing gears, bigger fuel pump and im about to upgrade my turbo. I just want a slightly bigger injector than standard. I have an R33 GTST with an RB25DET in it.
555cc if you go a 3071 or smaller
740cc if you go a 3076 or larger
740cc minimum if you are going to run e85
1000cc if you want to shoot for more power on e85 later on
thanks thats what i needed to hear
get ones with a decent spray pattern as well, don't just look at the cc rating.
Which ones have good spray patterns then?
I mean i got these sard dual spray ones (designed for JZ engines) that dont seem to have a spray pattern really they just shoot 2 huge jets of fuel out, have read somewhere they can spray into the walls on RBs ..Dunno if thats any good or not but they work ok..Definately can supply a heap of fuel..
Edited by Arthur T3
I wouldn't know to be honest, I haven't been injector shopping yet. But I do know that there is an appreciable difference between cheap and good ones.
Start googling for reviews and tech articles, that is what I would be doing.
Edited by Rolls
Not to worry, I did some googling when i got them but didnt find alot, they're already in the car and working fine, if they stop working then i will worry.. :D
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
