why? theres twice as many joints to fail..
Yeah only if the joints used are under rated for the application. Many 500hp applications still use the factory tailshaft.
2 piece shafts are stronger. It's a fact and any driveshaft specialist will say the same.
Going back to a previous post by someone, the falcon tailshaft made from alloy....Aluminium is lighter, therefore it has a much higher critical speed and they use a 3inch tube from memory. The longer the shaft, the stronger the material has to be or you have to lighten the shaft and/or make the tube diameter larger as well. The larger the diameter and the lighter it is, the critical speed goes up further. That is why carbon fibre shafts are probably the best material you can use. Extremely strong, extremely light.
About 6 months ago I got my 2 peice rebuilt from my 300rwkw R34. 1st drive I popped the clutch at about 4k RPM in 1st and blew 3 uni joints to peice's. I then returned said tail shaft and it was then forwared onto spicer, who refused to warrant the parts as they beleived I had either put huge power or locked the shaft some how. My question was, "how would you suggest a way that I could snap all 3 uni's in 1 go with out smashing out the bottom of my car?" they couldn't answer me. Luckily the workshop that built it for me where as confused as I was and met me half way with building a complete new 1 peice shaft.
A 1 peice shaft deffinitly transmit alot more vibration into the car but from what I can tell should almost be indestructable as it's much bulkier then original.
regards
Chris
About 6 months ago I got my 2 peice rebuilt from my 300rwkw R34. 1st drive I popped the clutch at about 4k RPM in 1st and blew 3 uni joints to peice's. I then returned said tail shaft and it was then forwared onto spicer, who refused to warrant the parts as they beleived I had either put huge power or locked the shaft some how. My question was, "how would you suggest a way that I could snap all 3 uni's in 1 go .......................
regards
Chris
Got any photos?
Reason I ask, the shop I use does routine maintenance work for BMW and Merc. Both these cars have non-replaceable uni joints same as the Skylines.
Whenever I get a shaft built it's done with new yokes that have conventional circlipped-in replaceable unis, there's very few Nissan components left when he's finished.
BUT the guys from BM and Merc won't have non-original components on their cars, they have the peened-in design yokes machined for circlips, pass them over to him and he re-builds the shaft.
There's practically no metal left in the yokes.
I'd be interested to see if your re-built shaft was done that way.
Got any photos?
hey Jiffo,
unfortunatly I never took any photo's of the shaft when it sheered all the uni's. I know exactly what your saying, yes the shaft was the peened style and machined the yoke to suit the circlip style. when it failed, none of the actual yokes broke, it sheered the actualle centres out of all of them. I would have though that machining the yokes would have caused them to be weaker and snap there first but it didn't.
Chris
lets see. i wonder what most race cars and drag cars use.. as long as the driveline angle is in check (most of the time its not..) i cant see any problems. besides a longer shaft will have more twist and hence be nicer to the unies..
i had massive issues with mine... and i needed a new cv joint.. but apparently... (i got told) that there is i think it was 3 bearings.. like a centre and a front and a back...
it was weird...
But i dont know too much about tailshafts.... plus i think that mechanic was dodgy....
lets see. as long as the driveline angle is in check (most of the time its not..)
Exactly right.
99% of owners don't realise you must run your flanges parallel.
That usually means packing the diff, stiffer engine mounts and some serious dimension checking.
Comparing a 25 box with a sliding yoke to a GT4 box with an output flange is also useless, the shaft must have some in/out flexibility either from the CV or a spline.
Running a sliding yoke style box with a worn out extension bearing is also asking for vibrations.
A stock 2-piece will let you get away with a lot of these faults, they may not even be noticed by the average driver, but a 1-piece will show them up big time.
Wonder how many 1-piece owners have fitted a shaft hoop where the centre bearing used to live?
  • 4 weeks later...
  • 1 month later...
  • 3 months later...
what sort of horespower are the stock 2 piece shafts cappable of?
i know someone earlier said they have been using around the 500 to 600 hp mark but what application are you using your car for? street, drift, drag, track?
if anyone is using a stock shaft with slicks at the drags would be handy to know the following..
*horsepower
*revs on launch
*tyres being used
cheers
  • 1 month later...
  • 3 months later...
just ordered myself a one piece cromolly tailshaft of uniqiue autosports for my r34gtr it has 360klw at the wheels,will let u guys know how it go's fingers crossed i dont get problems, its totally made will all new parts and its costing me $1500 john seems to know his shit we running a cv type flange on the rear and beefed up unis on the front with mark williams yokes
  • 7 months later...
I have a new shaft being built atm, im running 3 inch heavier tube, with uni's that are a 30mm cap x 90mm uni with external clips and all replaceable uni's. Will be a 2 piece shaft. The builder said they make them for 1000hp drag cars with no failures. Should well exceed my needs.
where are you looking at getting these built from? is their specific shops that specialize in performance tailshafts?
Hardy spicer
Fark! i've got a 1 piece built by ADL, it's been fine so far, fark! i'm going to have to change it
Why?
Hardy spicer
Why?
Ring any tailshaft maker in your area and they should tell you that a tube shaft of the length required in a skyline (I think it's around 50inches) will go critical at 6000-6500rpm. The harmonic inbalance is usually so harsh that they bend or buckle as a result.
Of course it depends on the material they are made from, how thick and the diameter of the tube but 2 piece shafts are stronger, much stronger. We put 600+hp through them all the time without hassles
this info seems to be on the money, my shaft is just over 50 inches :whistling: , compared with 4wd which is around 10 inches shorter
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
