The real problem here is that no one has called Nissan to inform them of their design flaw.
They clearly over spent on the much more expensive 2 piece design when they could have saved all that money making 1 piece shafts.
Forget engineering rules. This is obviously an oversight on their behalf. Someone should notify them
I asked these questions when it was made!
I picked up a 2 piece yesterday, gutting thing is I’ll need a second driveshaft loop and it certified!
I’m not keen on a high speed moment with the tailshaft doing some dub step death vibration
I’ll get onto Nissan and tell them to stop wasting time and money on the tailshaft and put it into forging the engine :domokun:
If you aren't having a problem with the shaft you have, why change it?
You will feel a vibration before anything worse happens.
It also depends on the material it's made from and how it was made (which is explained in detail in this thread).
If your shaft maker has made it from the correct material for the length and diameter then it might be perfectly fine
Remember that the critical speed is tailshaft speed, which you will only reach when you have very high road speed. 6000+ rpm at the tailshaft is fairly hiking, and is not going to happen on the road very often, and not happen on many racetracks for long either. That said, on a racecar, that will do that speed maybe once or twice every lap....you'll eventually have a bad moment, and that bad moment will upwards of 200km/hm, which you won't like. So, not a risk worth taking on a race car, and strangely enough, probably perfectly fine on a road car.
That said, I like the 2 piece design. Engineering wise it is much smarter, and does a better job of separating any movement of gearbag relative to diff from each other - not that it matters so much in an IRS car.
But for my overall preference, the only engineers who have ever really showed an interest in doing it properly are those from Peugot and Porsche (and a few others) who used a torque tube. I can remember reading that the solid driveshaft up the centre of the torque tube on a 928 was capable of absorbing something like 7 or 11 complete twists as it loaded up on launch with a 500+ HP engine in a race car. That is some serious business.
Steel does not have a fatigue life, it has a fatigue limit and as long as it is operated at a stress level below this then it should last for an unlimited no. of cycles.
6000 tail shaft rpm is the same as 6000 crankshaft rpm in 4th gear.
That's 111km/hr I'm pretty sure.
i think 4th at 6000 is around 165 ish km/h (with 4.3 diff)
Yeah my bad. I'm using an imperial calculator and that's MPH not KM/H.
So with a 4.11:1 it's 178km/h at 6000rpm on a 235/45/17 and 170km/h on a 4.3:1
Got my tailshaft today, I opted for the biggest unis I could get, they built the entire shaft using my old centre plates, and my sliding spline drive. Made everything else, heavier tube, 90x30 uni's that are solid, no grease galleries. The bloke at hardie spicer said it'll handle 1000 odd hp, and massive tourque, so I should never break this one!
I did have to flare the end of gearbox cover/shield to allow the uni to clear.
Best bit, replacable uni's!!!!
If anyone wants better photos of details etc just ask..
That shield can be knocked out quite easily if you have trouble with it fouling. It's a dust guard for the rear seal so can be ditched with only minor ramifications.
Yeah I popped it out to flare it a little, id like to keep it on, but if it gets in the way still, ill machine up a s/s one the right size ;)
This is what happens to a single piece tailshaft at 8,300RPM. Its in an AE86 so the tailshaft isn't exactly all that long either. Guy had a tailshaft loop as well, it ripped it clean out, took half the gearbox out with it along with the shifter and the fuel lines. Punched 4x big holes in the floor.
There is another guy here in SA that had a Cefiro. Freshly built car, new very expensive engine, clutch, gearbox etc etc.
Tailshaft failed in 4th gear when he attempted his scando into turn one at Mallala. The shock was so severe to the car that it the car actually buckled, destroyed the gearbox and engine. Car was pretty much gone because of a failed tailshaft.
I for one, will not be putting my single piece shaft back in.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
