The real problem here is that no one has called Nissan to inform them of their design flaw.
They clearly over spent on the much more expensive 2 piece design when they could have saved all that money making 1 piece shafts.
Forget engineering rules. This is obviously an oversight on their behalf. Someone should notify them
I asked these questions when it was made!
I picked up a 2 piece yesterday, gutting thing is I’ll need a second driveshaft loop and it certified!
I’m not keen on a high speed moment with the tailshaft doing some dub step death vibration
I’ll get onto Nissan and tell them to stop wasting time and money on the tailshaft and put it into forging the engine :domokun:
If you aren't having a problem with the shaft you have, why change it?
You will feel a vibration before anything worse happens.
It also depends on the material it's made from and how it was made (which is explained in detail in this thread).
If your shaft maker has made it from the correct material for the length and diameter then it might be perfectly fine
Remember that the critical speed is tailshaft speed, which you will only reach when you have very high road speed. 6000+ rpm at the tailshaft is fairly hiking, and is not going to happen on the road very often, and not happen on many racetracks for long either. That said, on a racecar, that will do that speed maybe once or twice every lap....you'll eventually have a bad moment, and that bad moment will upwards of 200km/hm, which you won't like. So, not a risk worth taking on a race car, and strangely enough, probably perfectly fine on a road car.
That said, I like the 2 piece design. Engineering wise it is much smarter, and does a better job of separating any movement of gearbag relative to diff from each other - not that it matters so much in an IRS car.
But for my overall preference, the only engineers who have ever really showed an interest in doing it properly are those from Peugot and Porsche (and a few others) who used a torque tube. I can remember reading that the solid driveshaft up the centre of the torque tube on a 928 was capable of absorbing something like 7 or 11 complete twists as it loaded up on launch with a 500+ HP engine in a race car. That is some serious business.
Steel does not have a fatigue life, it has a fatigue limit and as long as it is operated at a stress level below this then it should last for an unlimited no. of cycles.
6000 tail shaft rpm is the same as 6000 crankshaft rpm in 4th gear.
That's 111km/hr I'm pretty sure.
i think 4th at 6000 is around 165 ish km/h (with 4.3 diff)
Yeah my bad. I'm using an imperial calculator and that's MPH not KM/H.
So with a 4.11:1 it's 178km/h at 6000rpm on a 235/45/17 and 170km/h on a 4.3:1
Got my tailshaft today, I opted for the biggest unis I could get, they built the entire shaft using my old centre plates, and my sliding spline drive. Made everything else, heavier tube, 90x30 uni's that are solid, no grease galleries. The bloke at hardie spicer said it'll handle 1000 odd hp, and massive tourque, so I should never break this one!
I did have to flare the end of gearbox cover/shield to allow the uni to clear.
Best bit, replacable uni's!!!!
If anyone wants better photos of details etc just ask..
That shield can be knocked out quite easily if you have trouble with it fouling. It's a dust guard for the rear seal so can be ditched with only minor ramifications.
Yeah I popped it out to flare it a little, id like to keep it on, but if it gets in the way still, ill machine up a s/s one the right size ;)
This is what happens to a single piece tailshaft at 8,300RPM. Its in an AE86 so the tailshaft isn't exactly all that long either. Guy had a tailshaft loop as well, it ripped it clean out, took half the gearbox out with it along with the shifter and the fuel lines. Punched 4x big holes in the floor.
There is another guy here in SA that had a Cefiro. Freshly built car, new very expensive engine, clutch, gearbox etc etc.
Tailshaft failed in 4th gear when he attempted his scando into turn one at Mallala. The shock was so severe to the car that it the car actually buckled, destroyed the gearbox and engine. Car was pretty much gone because of a failed tailshaft.
I for one, will not be putting my single piece shaft back in.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
