Hi all
Got some r33 parts for sale, all from an r33 gts n/a s1 1993
location is geelong,victoria
some things will be posted some wont.!
2 pod filters – simota racing sports- $50 , calibre-$60
s1 stock spoiler ( colour is like a blue/green)-$120
s1 top dash-$90
s1 centre dash ( has a little crack )-$30
s1 boot liner ( the part were you stand ) -$20
s1 glove box ( has few wholes in it due to first owner)-$15
s1 door interior skin (passanger, few dints )-$30
s1 rear parsel shelf-$15
s1 back interior (drivers side)-$20
s1 back interior ( passenger side)-$20
s1 door handle ( passenger )-$40
s1 door trim ( drivers side )-$15
s1 door trim ( passenger side )-$15
s1 auto shifter cover-$10
s1 fan control( bottons need springs)-$20
s1 steerin wheel cover ( neck )-$15
s1 centre glove box- $20
s1 key cover-$5
s1 front seat buckles-$30
s1 power/snow button-$20
s1 centre box ( thing under radio )-$10
s1 speedo viser (cover)-$15
s1 rearbar skyline garnish -$25
s1 under steering wheel dash-$15
s1 rear back fuse/battery terminal-$40
s1 rear upper interior (driver side ) -$20
s1 rear tail light ( passenger side )-$25
s1 rear tail light (drivers side)-$25
s1 front bar indicator ( only one, dunno were other is)-$15
s1 passenger side top interior-$20
s1 drivers side top interior -$20
s1 rear view mirror-$20
s1 driver left knee interior (part of centre console area)-$10
s1 speedo-$30
s1 holy shit handle ( one )-$10
s1 centre roof light-$10
s1 sun visor ( passenger side )-$15
s1 seat belt attachment on middle pillar ( passenger side )-$5
s1 front roof light -$10
s1 mirror (passenger side )-$50
s1 interior door handle ( passenger side )-$5
s1 window wipers dash cover-$60
s1 rain guard for window ( drivers side)-$60
s1 rain guard for window (passanger side )-$50
s1 stock front bar-$120
s1 stock rear bar ( has a little damage )-$80
s1 drivers side window ( with tint, but needs new tint, in picture just sticky tape marks on it )-$70
s1 boot ( has little dint ) -$70
s1 door ( passenger , few scratches)-$70
s1 quater pannel ( drivers side, also has a little bit of rust problem down the bottom )-$40
s1 left side head light ( 2 of them ) each-$20
s1 right head light -$20
s1 back steat-$90
s1 front drivers side seat ( litle bit of wear )-$60
After market Do-Luck front bar and side skirts also for sale. Unused needs painting. frontbar-$160 skirts-$120
https://www.sau.com.au/forums/topic/351457-r33-part-sale/
  • 4 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
