Hey guys,
Just got myself a new boost gauge and i'm trying to work out the best place to mount it. I've done a few searches and found what appears the be the best vac line to tap (the one that runs from the back of the plenum then runs left to the back left hand side to a little black box, which i am told is the stock boost sensor). My only conundrum now is trying to work out where to put the gauge.
I've spent alot of time sitting in the drivers seat and placing the gauge holder in different places, but i cant seem to find a place that combines easy access to wiring and a short route through the fire wall with a useful legal line of sight mount.
I'm been pondering trying to mount it at the base of the drivers side a pillar, its below wheel level and still sits within my view when i look straight forward, but when i look at the available holes through the firewall it makes it look like i'll need to pull the whole dash.
I've also found the DIY posted on here, which is good but is now sans picks so i'm pretty much guessing that i'm looking at the right thing.
Can anyone give me a few pointers or anything to think on / consider?
Cheers
M
https://www.sau.com.au/forums/topic/35147-best-place-to-mount-a-gauge/
Get an apillar gauge holder and put it on there.
Its an Apexi EL mech gauge so it comes with a mount. My prob isnt mounting it really, its more a case of getting the tubing and wiring the the gauge. I'm not sure how to get to the hose once i've pushed it through the firewall, which hole to push it through (although i think i've spotted a good one) and how to get it from there to the a pillar.
Maybe i just need to have a good long play, but i'm hoping to avoid pulling apart more than i have to.
I got exactly the same thing, but get yourself a greedy single apillar gauge holder.
Pass the rubber tube through the firewall just under where the abs sits and a whole bunch of other wires are going through. Then get a piece of wire and pass it through to the drivers side and to the holder.
do be careful if you are mounting it on the A pillar. Alot of people mount their guages there, but I find that when you are punting hard at night, the guage sort of gives you a slight blind spot if it is mounted wrong - makes life a bit difficult for tight right hand corners.
Not sure about sydney, but in SA it is also illegal to mount guages on the A pillar. I have been told this is because it 'may' increase the chance of head injury in a collision (right, like you are going to be more concerned about the pillar guage than your head hitting the a pillar or windscreen a poofteenth of a second later????).
the best place I have seen is inside the instrument cluster. You can use double sided tape to secure it infront of the stock boost guage, and run the wires behind the steering column - under the instrument cluster, so no holes needed anywhere.
The other thing to consider is that when you are boosting, it is unlikely that you will be watching the boost guage anyway - at least I dont, things happen too quickly at full boost to be paying too much attention to anything but the road:)
Maybe for you Steve :( There is time in 3rd gear though... definitely not in first.
finding the correct vac line made me realise that i dont know where/ what most of the engine parts are... does anyone know of a good place or pic that will help me learn about a 33gtst engine bay and component locations??
Personally, I think it looks great mounted above the central air conditioner vents -- if the mount is like the GReddy ones, it'll require a little bending to give you LOS to the gauge.
I think A-Pillar mounted gauges are illegal in all states (it's a safety-related ADR), so it's probably best not to put them there.
It aint illegal if its not in your line of sight. If u have air bags u r gonna hit the airbag before u get anywhere near the a pillar anyway
i know for a fact in wa its not illegal to have pillar mounts, mine went over the pits
no probs, they also gave me a permit so i wouldnt be haseld. It does have to be set back behind s-wheel distance(reason of hitting head). I also think they mite have a prob with crome cups, but black is fine if mounted in correct position.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
