First owner in Australia, Imported in 2007 in Pristine condition with 58,000kms. Regularly Serviced with fully synthetic Motul oil.
BRAND NEW POTENZA RE001's Fitted one month ago on the Genuine Nismo LM GT-4 wheels (worth around $3500 alone) 6 months Registration
Engine:
All engine parts bought new
GCG Garrett 550hp Turbo
3in Dump Pipe with Screamer Pipe
3in Hi-flow Cat Converter
Apexi N1 3.5in GTR Exhaust
Nismo 555cc injectors
Walbro 550hp fuel pump
HKS Super Airflow Pod filter
HKS SSQ Spec 2 Blow off valve
Trust spec LS intercooler
Greddy trust E-manage Ecu
Z32 AFM
Greddy profec b spec 2 EBC
New Engine heater Hoses (worth over ($400)
Have Dyno Sheet for 263rwkw but that was with stock dump, should be making more
Driveline/Suspension:
Exedy Ceramic 4puk clutch
New Clutch Spigot bearing
New flywheel thrust bearing
New Nismo Clutch Pivot ball
Nismo 2 way differential
Nismo S-tune suspension
Nismo Suspension arms
Nismo Strut braces
Project Mu SCR Rotors only installed 3 months ago with Project Mu Club Racer pads
i have Nismo R-tune brake pads too
New tie rod ends Race ball joints up front
Exterior:
Nismo Bodykit
Custom Nismo Front bar
Nismo Clear Indicators
Nismo Carbon Fibre Pillar Garnishes
GTR Rear wing Nismo Carbon Fibre Wing Caps
Nismo Front/ Rear decals
Nismo Rays Engineering LM GT4 Forged Wheels/ Potenza tyres 225 front 255 rear
Tinted Windows
Interior:
Nismo 400R Bucket seats
Nismo Gearknob
Nissan Carbon Fibre handbrake
Carbon Fibre Dashboard surround
Kenwood CD-mp3
Some Parts can be removed possibly for price negotiation, have all standard parts also eg. rims/seats
Some SAU: SA guys know the car, i have been extremely fussy with it, so if you want a great quality r33 with a seller that'll provide every detail of its history, then this is the one!!!!
Price : $21500
THIS WEEK ONLY : $19,000!!!
PS. MORE PICS TO COME!!!
https://www.sau.com.au/forums/topic/351470-r33/
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
