Gee Thanks GUILT TOY ass i didnt try that mate.......searched it on google only found forums were people had been disscussing the ECU. I wasnt aware it had a dash in it.
Be thankful he didn't tell you how retarded you REALLY are.
http://www.google.com.au/search?q=vipec&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
$20 says you didn't search google for "vipec", even without the dash. Lighten up and perhaps be thankful he even took the time to reply to something so silly.
https://www.sau.com.au/forums/topic/351471-vipec-ems/#findComment-5643166
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
    • No idea. It's too weird.
    • The jack holds itself in place. You slip it down into the receptacle and give the input a twist to open it up a little and jam itself in there.
