so today my car's speedo started playing up
first, it wouldn't read past 110km/h instead it would just drop to 0km/h and stay there until i went below 110km/h then it would start to read again
few hours later, it stayed glued to 0km/h and my check engine light came on and stayed on. switched the car on/off and drove around and it was the same, speedo not working at all and engine light on
anyone have a clue on what could be the problem?
thanks
i had a look under the car and checked the gearbox and diff. all plugs/wires look fine and connected
i also pulled out the cluster and checked the wiring behind it and all is fine there too.
whats the next step?
could it be the cluster itself thats faulty?
  • 2 years later...
I am having the same problem after I have replaced all the tail light bulbs.
Please help. :(
No bro, mine doesn't even read at all. Except last night, it started of on 60 when the car was standing still, it went to 170 when I was going at 60 according to the Gps.
This morning it didn't work at all.
  • 2 years later...
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
