* For Sale * Skyline Bits, Wheels, R34
i have for sale:
- 19 inch starcorp racing rims, dont know exact sizes but they where fitted on an R34, rear tyres are 265 35 19 hankooks (90% new) fronts are 235 35 19 (80% new), also comes with 25mm front bolt on spacers and 5mm rear slip ons, with out the spacers these rims foul the calipers on an R34, but they look mega tough with deeeeep dish. one of the rear hankooks may have a very slow leak, however i cannot confirm this as the wheels where taken off to be replaced by the stockies for sale of the car. $750
- R34 Hybrid FMIC, the chrome coating is peeling off the aluminium pipes but the plenum is perfect just needs a clean, polish the pipes and they would be as good as new, no leaks. $200
- R34 Greddy air intake and pod filter w. sheild, awesome induction noise, would suit other cars with similar afm holes. $100
-R34 boss kit and quick release Momo Race wheel and hub. $150
-R34 Neo engine cover $50
-R34 LHS Xenon headlight, plastic cover is broken but bulbs might still work and computer is fine. $100
-Blitz BOV, was fitted to an R34, may fit other cars, iconic sound. $100
will post up photos tomorrow.
might have some other stuff im forgeting, will update.
0437 580 599
or PM
https://www.sau.com.au/forums/topic/351520-for-sale-skyline-bits-wheels-r34/
IMG_0106.jpgIMG_0114.jpgIMG_0112.jpgIMG_0103.jpgIMG_0100.jpgIMG_0099.jpgIMG_0095.jpgIMG_0082.jpg
correct phone number is 0437 580 559, the one in the main post is incorrect.
located just outside devonport.
- also for sale is an Top Secret R34 front bar, fibreglass, brand new, has a small crack from the couriers being rough, but easily fixed and i will supply the glass and resin if required, or a body shop would fix it easy. cost $700 plus $150 postage to tas, will sell for $300.
top secret front bar and bov sold.
still for sale:
- FMIC for R34 good condition price drop $150
- Momo Race wheel and quick release boss kit price drop $100
- Blitz air intake price drop $70
- LH Xenon R34 headlight price drop $70
  • 2 months later...
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
