No Jimbo, the first one was fine because you had all this in lowercase:
yo.
just a trivial thing, if you've got you're caps on trying to yell in a post after you submit it it either is all in lower case or only th first letter of each word is upper case
It only changes "TEST" to "Test" when your ENTIRE post consists of capital letters, and I think that's a good thing.
https://www.sau.com.au/forums/topic/35154-capital-letters/#findComment-702469
I agree it is a good thing and it stops annoying noobs, but in my case where i was trying to yell in bmans, majanal thread that i noticed its a problem.
pro's definatelt outway cons though :(
https://www.sau.com.au/forums/topic/35154-capital-letters/#findComment-702519
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 馃ぃ As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
