so are we just picking on 35's or can we blame the mazda 3's also
I followed a 3 up Henry Robert today and it went quite well. Apart from that I am a bit confused.
But is that normal??
https://www.sau.com.au/forums/topic/351561-xrg375/#findComment-5641723
+1 for the 1000 pages ;) maybe we should all start a class action against the government (ah la vodafone) for never teaching ppl to drive in the first place. we could all claim to have PTSD from driving on the rd with them. but seriously, these threads can be a good for venting frustration, but careful you dont get it closed. my gripe goes to all the van and SUV drivers out there!! get the F#%K out of the right lane when our not overtaking!!
https://www.sau.com.au/forums/topic/351561-xrg375/#findComment-5642822
Why limit it to van and soft-roaders?
ANYONE doing either the speed limit or under should get the f**k out of the right lane.
If you are overtaking, please do not do so by travelling 1 or 2kph "faster" than those in the left lane, just get the hell around them and get outta the way FFS!
https://www.sau.com.au/forums/topic/351561-xrg375/#findComment-5643335
+1 ^^ for hughesy looses it!
but not only the right lane, when theres a free lane, and your about to turn onto it to speed up abit, then someone decides to go in that lane and just cruise 10k's under the limit!
Why the hell do they need to go into that lane, when they we're going just as slow/fast as the one they were in which wasnt free.
https://www.sau.com.au/forums/topic/351561-xrg375/#findComment-5643362
I call them "Community Police",:rant:
They spend their lives getting everyone's way, so that nobody does things that they don't think should be happening; ie, Speeding, drinking, people having fun, etc
I followed a woman in a Landcruiser for 15km last week, who sat, pacing along in the right hand lane, next to the right hand rear wheels of a Semi trailer ; too scared to go past I imagine, but plainly too stupid to realise she's sitting in the most dangerous position possible.
Eventually, the truck driver virtually ran over the front of her car changing lanes to allow the traffic to pass by in the left hand lane. All the while she was trying to cut back into the left lane to block the traffic again.
Didn't want to go past, just didn't want anyone else to...
That part of my trip took easily 15 mins longer than normal because of this brain donor...
Edited by Daleo
https://www.sau.com.au/forums/topic/351561-xrg375/#findComment-5643385
community police? lol I call them f**kin dickheads.. with my window down as Im driving past..
Yess, Im a rager
https://www.sau.com.au/forums/topic/351561-xrg375/#findComment-5643392
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
