  • Replies 44
I can look over that link above again and again and sure, the car is a bit twitchy with stock V-Spec suspension; however...
* it's a glorious run
* it's a glorious car
And I defy any R34 GT-T or V35 GT to get anywhere close to what the R33 GT-R can do.
Remember the car in that link is bone stock!
Just with S-Tune suspension, Kurosawa could knock off another 3 sec. With bone-jarring R-Tune suspension, another 7 sec.
Are you after "driver satisfaction?". Driven a couple of R33 GT-Rs?
Several people here rest their case!
couldnt agree more. sweet video.
i bought the 33 purely for the sake that i think it looks better than a 34 imo (talking gtst/gtt) 34 is just too square on the back. esp without a wing.
Maybe some pics can help you make that decision.
I had wings on my first few R34's, but after driving this shopping cart around -
I started shaving them.
post-86021-0-66147600-1328181467_thumb.jpg post-86021-0-31383500-1328181479_thumb.jpg
It really depends on the look you are going for and what you've done to the rest of the car though.
V35's look great with the factory wing too -
I had a silver V35 coupe - 2004 model / grade 4A.
Got bored of it real quick and bought a 350z convertible and a 350z hard top instead.
Im assuming Chris above is referring to the window motors and the door lock actuators. If so, $1000 is actually a cheap quote if thats for both sides and both parts - i'd suggest you keep his number handy as you'll definately need it.
From personal experience - Having also owned a series 2 R33, R33 GTR, S15, quite a few R34's - when I compare the older models to the new, Nissan dont seem to make them like they used to. Design faults with the above mentioned parts along with other design faults you'll find as you go along (like the roof on the 350z convertible which kept tearing around the rear window).
Personally, I would not recommend a V35 unless you really, really like the style and really need the back seat. Otherwise if you're after a car that is similar - go the 350z. Will also be easier to sell later when it comes time to move it on.
exactly what I was getting at. parts for them are not cheap. with the amount of electronics in that car its only a matter of time before somthing major fails and cost $$$ to sort properly.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
