Hi guys,
Putting on an external gate GT3076 0.82 in the next few days. Got a PFC, Z32, 480cc injectors, bosch 040, splitfires.
I'm obviously going to have to get a tune from my favourite man in the world, Gavin Wood. I've just been browsing the E85 threads i found with a search, and it looks to me like I might be able to buy some bigger injectors (and maybe a bigger fuel pump?) and then go for an E85 tune, as there is an E85 petrol station 10 mins from my house.
From my reading, lots of people seem to think i don't need new fuel lines or anything, just regular fuel filter replacements for a little while. Others seem to think it will melt my fuel lines, then the whole car itself, til i'm left with just a puddle of skyline in my garage.
Is there much benefit to going to E85 for a 99% street car? I was going to get it tuned at around 280kw (1993 unopened rb25, so i don't wanna push it too hard), but from what i've read, looks like tuning for 300kw with E85 wouldn't be any more strain on the engine, while giving me more peak power and more midrange torque.
The next logical step is to talk to my tuner about it, but it's 9:15pm, so it's gonna be 12 hours before that happens. I'm fully aware of the 25 perfect more fuel usage and 20c cheaper per litre, but i'm okay with that :)
  • Replies 42
i converted my GTR to caltex E85 4 weeks ago and it hasnt melted yet, havent changed the fuel filter or anything, im running 293kw with 660cc inj at 100%, so make sure you get some pretty big injectors for the power your chasing,
E85 smells awesome too, if you dont mind fueling up at only a few servo's and you dont drive your car on long trips i would go for e85, im getting around 320km's to a tank with fairly sensible driving compared to 380 or so with BP98.
i didnt see any power gains with my setup due to my N1 turbo's holding it back but i love the $1.05 per litre, and its also the safety margin you get with E85 being 105ish octane
I haven't killed my fuel system yet, I've been running it for a year or so. A lot of people confuse it with methanol which will eat exposed alloy etc.
I just found out 24 psi and ethanol's massive torque isnt good for a built re5ro5 trans. :( Looks like I will have the first manual M35 stagea, anyone know of an R33 gtr box going cheap? lol.
There's at least one manual M35 in Syd already-sorry to burst that bubble
Logically - at the present time - No.
E85 availability is still problematic, especially in Vic and other states.
I mean yes you have one around the corner so to speak, but going on a reasonable 3hr spirited drive and having to take 2 jerry cans is the pits!
It would be viable in a few months as its slowly appearing more and more, so mid year would be a better time IMO to be looking down that path.
Will also allow you time to shop around and get a good price on injectors as a few people seem to be upgrading of late ;)
Not sure where you read all the other stuff about melting fuel lines... I don't recall such rubbish being posted here :)
http://www.caltex.com.au/ProductsAndServices/Pages/BioFuels.aspx
I also a read a commit to something like 400 pumps across australia by the end of 2011. Personally the local just installed an E85 pump so i'm going straight to RB25de+T from an R34 into my spare 32 sedan :D.
Being as a lot of stations mix the E85 themselves and hence has pretty bad variability how do you tune around this, being as alcohol needs to be richer than petrol, do you just purposely dilute some fuel to say E75, tune with that as a buffer and deal with the fact that it is running slightly richer than needed?
Thats about right, tune rich on the e70 in the pumps now and it should run fine if they ever change to e85, which they don't seem to be doing this summer...
Remember the fuel in the servo tanks will be diluted, and the fuel in you car's tank so it wont just swap to e85 on the next fill anyway. I run a wideband and check WOT after each fill, it keeps me happy.
i wish i had e85 on pump in tassy. i rang the bp and shell depots for tassy last week and both said they have no plans to bring it to tassy at this stage. they dont even bring 200 litre drums in.
Someone has mentioned they use a re-usable washable fuel filter when using E85, but can't seem to find the author.. I'm after a link to this product.
I just use a disposable metal commodore one, $10 at any parts store. I have used a proflow one, they aren't bad but they wont warrant the rubber oring seal for ethanol use.
It actually says on the caltex site that they change from 70-85% depending on the season.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
