Does any1 know of C and V performance? Are they good at tunning, especially tunning the FC?
Does anyone recommend? If not, who else do you reccommend? Also i am in sydney.
Cheer All
Apparently Croydon are the only ones in Australia that have the software, all others tune off hand controller. (With software there is at least 30kw more)
https://www.sau.com.au/forums/topic/35160-power-fc-tunners/#findComment-702523
But wouldnt using the hand commander be better? because you are using the FC's own tunning product? Im using CRD developed thier own program because they were tunning the FC's before the hand commander came out.
If this is true, then wouldnt everyone go to CRD?
https://www.sau.com.au/forums/topic/35160-power-fc-tunners/#findComment-702988
as far as i know the PFC HC has been available with the FC since it was invented.
the laptop software allows them to tune in 300 units instead of the 60 units that the HC allows (not the right figures but you get the point)
i would also guess that the laptop software will not guarentee any extra power just easier tunability thus more can be done a lot easier and quicker.
https://www.sau.com.au/forums/topic/35160-power-fc-tunners/#findComment-703242
Bullshit about the laptop software for PFC - A good tuner can get the same result but it will take longer. The HC is awkward and lots of writing on paper. But if they know what they are doing , not having the Datalogic whateva is not entirely neccessary.
My 0.2c
https://www.sau.com.au/forums/topic/35160-power-fc-tunners/#findComment-703269
My 0.2c
Correct
https://www.sau.com.au/forums/topic/35160-power-fc-tunners/#findComment-703598
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
