ok guys got under it today,
hks dump ID - just under 69 mm
dodgy tasmanian backyard exhaust ID - 59mm
plus the welds are f**ked on the inside so i guess that would choke it a bit more.
ill get it fixed and retuned as soon as i can.
one final question, would it be worthwhile losing one of the mufflers while i get a new front pipe made? i actually enjoy how quiet it is, but i dont really have any idea of how much power they leach.
I think because the diameter of the turbo is that size,
Makes sense.
why they don't smoothly taper out to the bigger size I do not know, perhaps it introduces turbulence which is a good thing for flow?
No, that's not it. I'd say it would be manufacturing cost of having a taper of the right length blend into the pipe bend which is quite close after the diameter change.
The only reason Greddy or others make those pipes is due to fitting up to stock or almost stock turbo combinations. Still no excuse though, The quicker the hot air expands into a larger pipe the better off you will be. I have spent considerable time confirming the differences between a 3" pipe and 3.5" pipe and there is definately power and more importantly quicker boost to be had in a larger pipe.
I will also tell you I am running a Garrett 3071 .82 housing which is considered the equivalent of the HKS turbo you have. If it were me I would replace the whole front pipe with 3.5" and know it won't be held back. I have seen other results where the cat back was changed to 3.5 from 3" and power increased. The whole idea of exhaust gas cooling after the cat is rediculous from a heat perspective. True, the exhaust manifold can glow red with heat while the exhaust doesn't while under load but the fact is, the exhaust is on it's way to glowing if the revs and load on the engine are kept up. And just because the exhaust itself isn't glowing doesn't mean it isn't bloody hot. That's how the cat works, by holding the various poisonous gasses a little longer and burning the shit out of them till there is less of it going into the atmosphere.
Get into the big Ford turbo forums and see the warning on exhaust size after 260rwkws. It must be 3.5" or better. Get this right, you will still do well with a 3" but best efficientcy is at 3.5". In the States especially there are so many bigger power cars having to go to 3.5" exhausts.
P.S: your dump pipe is crap, no, I mean it is really crap. Like whoa, that is sooooo........CRAP.
Edited by skylinecouple
Your post confuses me. Firstly you recommend a 3.5" front pipe, then say people have gained power by going back from a 3.5" to a 3" catback exhaust and then completely deny the exhaust cooling idea. If you dont believe in this what do you think it is the reason?
Surely the exhaust is hotter at the start and cooler by the time it exits the rear tip?
Then after saying people have gained power by going back from a 3.5" to a 3" catback exhaust you quote many cars needing to go to 3.5" exhausts??
I value your opinion as your suspension experience helped me solve my axle tramp so I am interested to understand what you are trying to say.
Untie your panties and actually read what he wrote mate.....
So it was changed TO a 3.5" FROM a 3"....................capeche?
HAHAHAHAHAHA woops, yup I did misread. So hes just saying bigger is better.
Its a pity that all off the shelf products for the RB25 I have found only come in 3".
EDIT: I lie, XForce sell a 3.5" catback option but nothing for the front half which I think is more important.
We dropped my 3" fujitsubo catback and it only made less than 5kw difference on the 280rwkw it normally makes.
yeh i know the front pipe is likely the problem, i said that i'll get it fixed in the last post (i.e a new one made up).
is there any benefit of having a 3.5" front pipe, if the outlet of the dump is only 69mm ?
heres a pic of the dump
well, i realise dyno's are only a means of measurement, but i'm convinced that my setup has seemingly less power than almost everybody elses thats similar, so im just trying to figure out what the restriction could possibly be.
here's a list of what's been done:
unopened s1 rb25det
ems stinger ecu
hks gt2835 pro-s
3" flexi pipe intake hose
nismo 740cc injectors
walbro pump
hybrid cooler
stock coils
exhaust that goes from 2.5" to 3", 2 mufflers no cat
18psi - 315rwhp
13.1 @ 109mph on 205 rubber
compression test came up as 150psi across all 6 cylinders
it holds boost through to redline, and im assuming the coilpacks are working as it doesnt miss. it has a stock fuel pressure regulator.
the most obvious thing i can think of is either the exhaust is restricting it, or my tuner isn't putting any timing into it?
any thoughts please punt them at me
cheers in advance
Same setup with stock manifold running a Z32 and PFC got me 350HP at the wheels at 18PSI, Same Injectors, Same Turbo, Same Fuel Pump, Splitfire Coils, howecer had a 3" front pipe comming from the HKS Split Dump, to a High Flow Cat into a 3" Exhaust.
Hope that helps.
Get a 3in bellmouth dump and front pipe in one, I'm not a fan of hks dump pipes and that front pipe is horrible, me and a few people I know are all getting rid of the hks dump pipes on our Gtrs due to us believing they are a restriction
    • I didn't know about induction heaters but checked them out and they look awesome but too pricey for the occasional job like this. And I'm too nervous to take a flame anywhere near there as the petrol tank is so close, although I was intrigued with the crayons suggestion 馃榿 I filled a coke bottle lid with penetrating fluid and raised it on the jack so the nut was submerged in it all night. Then went in with a tiny cold chisel and got it almost to the point of splitting but not quite (I didn't want to damage the bolt threads). Then I hammered a socket back on and gently worked it until I felt movement. And it's off 馃榾
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
