You didn't mention the exact areopro box, some I'm assuming this one
Aeropro
if you notice its not a litre, so it would be a very poor sounding box, if you have the sealed version , take 1 bag of loose polyfill stuffing from spotlight or ? and lightly fill the box after carefully removing the sub. your not looking to fill it tight, just handfuls chcucked into it , use 1 bag full roughly about 7-8 bucks I think. don't fill it so full the sub frame hits the stuffing, this will trick the box into thinking its over a litre in size. you could also invert the sub to gain a little more box space but risk hitting the back of the speaker with crap in the boot ? you must have a good airtight seal ?
as you can see below a ported box is bigger but the sound would be a bit better, slightly louder as well.
reccomended box sizes
Ported Box
Fusion EN-SW120
Volume (litres) 48.28
Volume (cu.ft.) 1.705
Port diameter " 76.2mm / 3"
Port length 225.3mm / 8 - 9 "
Tuned frequency (Hz) 33.0
Sealed Box
Volume (litres) 28.58
Volume (cu.ft.) 1.009
Tuned frequency (Hz) 53.9
if your running both the crossovers on the deck and amp, it will cause phase issues, try running the amps - sub crossover at 80-100HZ and no radio xover, but sub out on.depending on which rca your using ?
with both on it can sound muddy bass. along with a small box it would lack , any hit
and run the front deck speakers on hpf to block the bass from the fronts speakers, if you can set the freq on them to 120-160hz. the speakers natural roll off will still play below that but not much. and safe the distortion at high levels.
oops sorry that amp is only 300 @ 4ohms, , but the matching one to yours is the same only a green case. you can use the other old amp on the front speakers ? would make a huge difference in loudnesss
tonight I'll plot your car out for max , bass , using your numbers, out of time now..lol
hope this helps a bit. cheap fix is loose polyfill
  • Replies 45
Very annoyed. wrote a long reply. nothing showed up. TWICE!
The prduct code for the box is, SB12100, advertised as a 1 cubic foot box. (tried linking it, kept being gay)
Got that seeing it was close to 1.009 and i couldn't find anything else as close.
My head unit has 3 rca outputs, Rear, front and sub. Rear and front are connected to my 4 channel amp. Sub output connected to the sub amp. I can turn the sub on/off with head unit along with invert it (aim the sub into the box) and adjust the filters. Gotta work out what the filters are cutting what to where. ie what channels. And i haven't seen any crossover function but will have a look.
Got a friend who works at spotlight so i will get here to score me some poly fill on the cheap.
Cheers once again.
Edited by Johny Bravo
your sub is designed for PORTED boxes. not sealed
your sealed box MAX DB is just under 115db at 20-100HZ, the bass is very flat and prob sounds horrible judging from the graph it ran.
the freq, you get at your windscreen is 186hz based upon your numbers, so your bass is more MID-BASS when your in the front seats
but at 7 metres from your car windows down the bass most likely sounds much better. shame you can't drive that far from the car. that puts it at 50hz
at 4 metres you would have a big boost at 80hz
in other words build a ported box, face the driver towards the rear of the car, as well as the port on that side as well
and you should be a lot better , deeper sounding bass. and power the sub with more power, still use poly fill on all the walls except the front in the ported box, but spray glue it on. don't compress it, just fluffy handfuls is fine. hope this helps
if you need help on box design I can forward the plans to you.
this is the size of the optimized ported box.
MAX DB for this box is about 120db at max power but less bass in the 45HZ region.
Driver Properties
Type: Standard one-way driver
Company: Fusion Car Audio & Security
Comment: Encounter series
No. of Drivers = 1
Fs = 28 Hz
Qms = 4.027
Vas = 123.9 liters
Xmax = 11 mm
Qes = 0.249
Z = 4 ohms
Pe = 200 watts
Box Properties
Name:
Type: Vented Box
Shape: Prism, square (optimum)
Vb = 45.36 liters
Fb = 32.6 Hz
QL = 6.873
F3 = 23.62 Hz
Fill = normal
No. of Vents = 1
Vent shape = round
Vent ends = one flush
design 2
MAX DB about 124db at full power using the current amp at aprox 45hz
Box Properties
Name:
Type: Vented Box
Vb = 43.68 liters total 46 litre's
Fb = 32.6 Hz
QL = 6.873
F3 = 30.43 Hz
Fill = normal
No. of Vents = 1
Vent shape = round
Vent ends = two flared
Dv = 76 mm
Lv = 243.6 mm
If you already have the plans that would be appreciated. But i don't want to put you out any more as you've already done so much. I'm following all that stuff to a limited extent. Which option would you recommend? should i turf the sub, amp and box and start from fresh? or should i just build a box to better suit the sub i have and get a better amp? Building a box should be easy enough for me to do. A tad broke at the moment so i can't really afford an expensive amp for a little while. Thanks once again for all the help. Is there anything i can do to thank you? Cheers.
Yeah I have the plans , I'll send them but confirm the opening size before building it, since I dont' have a R31 sitting in fornt of me..lol need height and width betweeen the arms of the boot lid, and depth from window lip to the seat back top.
the box would be the easiest route , sell off the sealed one and build a ported one the right size. then buy a bigger amp down the line, you can never have too much bass...haha
Yeah will measure as much stuff as i can and send you the dimentions as soon as get around to it. Little drunk at the moment so i think i'll wait till the morning. I think i'll take a picture and draw all the dimentions on top. Should make it easier for you.
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
