What's Going On With Stathfield Morayfield?
Hi guys,
Any one know what's up with the Morayfield branch of Strathfield.
They have been closed for 2 weeks now, and they installed my alarm/immobilizer nearly 2 years ago and now it is being very temperamental.
I figure since they installed it, they can look at it only problem is I can't even contact them.
I have left emails, called repeatedly, called other branches (slacks creek was useless) and I can't get thru to anyone.
now my car won't start sometimes due to the immobilizer being active and the central locking has stopped working, I'm at a loss as what to do with my situation.
I have even threatened Strathfield that if I didn't get a reply within a week I would be seeking further action, and that was last monday 17/1/11 well over 7 days now.
The goose I spoke to at slacks creek basically told me he didn't care that they were not open because it was shut due to 'health and safety' reasons.
Being heavily into workplace health and safety (whso/rep) I know this is not the case they should have been opened up by at least last Wednesday, (unless they have some retarded policy stating other wise)
I doubt I have any sort of case against them so seeking further action would be a stupid waste of time, money and effort.
would it be worth calling up Cyclops alarms to see where the next closest distributor is and working it out from there or should I wait for Strathfield and sling them abuse when they finally open their doors?
Any advice would be handy :)
thanks
When I spoke to the Slacks Creek store I asked for the regional managers/Rep number and the person I spoke to refused to give it to me.
EDIT : I just googled "strathfield headoffice number" badabing badaboom. I'll try it in the morning.
I don't know why I didn't think of it earlier, thanks.
any other advice is welcome.
Edited by omy-33
Seeing it was over 2 years ago, you may no longer be covered under warranty. It may not be that the product is faulty but there's something has come loose and it would require someone to get in there and have a look. Not exactly the same field but in the computer store I worked in for a while there was a 7 day warranty on labour. Might want to check out the invoice and read through the fine print, might speed things up for you a little and you can take it to someone else who will answer your phone calls!
Hrm yeah sounds a bit suss. I'm just guessing here but maybe if they're separately owned stores that one went broke? Dunno. The difficulty you're having getting a straight answer doesn't fill me with confidence in any case.
If you don't have any joy with getting hold of them, or need it fixed ASAP, +1 for Audio Express. If anyone can sort your alarm out it's Chris :)
dunno,
gievn that thye screwed the franchisees out aof a LOT of money when coporate took them all back over, I dare say that the corporate office has shut that one down as well. I know the rocklea one (mal meninga) went down in a ball of flames that way.
when it went franchise they still expected the franchisees to put their daily takings into the SCR account and not their own accounts. (as you are supposed to do.) the staff at the time lost everything - holidays,sickleave - the lot.
if its flood related then you may be in for a headache as they *may* turn it into a phone stall in the main shopping centre. cheaper for them and less headache to refit the store.
as for your issue. I sell the cyclops units. is your remote the arrow head or a different one?
have you changed the batteries?
if arrow head - pull the unit apart and give it a GOOD clean. those had a nasty habit of dying due to dirt. (the buttons are mica based and do not conduct after a while.)
if all else fails - toss it on a truck and send it down to me. I'll fix it.
Ok thanks for all the advice, it has been a help. I agree with you that abuse is not going to help anything. My diff should be in within the next fortnite so you will probably get a call from me soon Chris.
In the meantime I will take apart the remote x2 (neither work) and clean it all out. The blue light comes on the remote but it's like the receiver has crapped itself, I used to be able to sit next to the car and just repeatedly hit the remote buttons for about 5 mins
before it would unlock, now I just keep it key locked and moved it inside the garage. lol.
So i'm not going to bother with strathfield anymore when the diff is in and the car starts i will just take it to Audio-express.
Thanks all
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
