I might be able to help a bit, even if I only have an rb25
I started out fitting an N1 system, 80mm. Flowed very well, straight through design with minimal bends. Made good power but was LOUD as hell - headache material. I sound deadened the boot, not so bad inside the car
I next got an 80mm Nismo cat back. Also 90mm with a big center resonator. It had more bends than the N1, it killed power and ended up choking the top end above around 290rwkw - it also gave me around 1000rpm more lag and made the car more doughy. But it was quiet.
I tried a 90mm N1 with small resonator on the back - I am sure it actually amplified the exhaust note - it was incredibly bloody loud, so it got take off before I even took it for a test drive.
Lastly I fitted a HKS super dragger, which is 90mm, has less bends than the Nismo exhaust, but not as straight through as the N1. It has a nice burble at idle, sounds angry as hell when you nail it, but is still quiet enough that its not annoying to drive around in, and if you want to just limp around when there are plods nearby, it doesnt attract too much attention.
Bottom line is, you need to compromise. The quieter an exhaust is, the more back pressure, the less power, more lag, doughier off boost.
I dont think there is any harm in going larger rather than smaller, the HKS exhaust still has a few bends (more than the N1) but the 90mm pipe seems to make up somewhat for the bends. Just make sure you have a nice resonator on the back to give it a nice note.
HKS gear works for me - bolts up easily, isn't overly restrictive and not droney like some custom made systems I have heard.
On a GTR - you'll be amased at the difference front pipes and terb extensions make as well.
A "Jap-Spec" cat also make a notable improvement to flow and spoolup response. Mr Plod may not be impressed if he finds out, however.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
