22psi is about what most people would run on that turbo, I'm assuming the motor is build and tuned for that? what is the issue?
You could have a boost line with a leak causing it to go higher than it should though.
Edited by Rolls
  • Like 1
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5641966
cheers for the input
ill check the lines again i replaced one coming off the fpr but that is all good now
my motor is not built for that power level and i don't want that amount of boost which is the root of my concern
my 755 cc injectors and haltech - rail etc etc all go in in a week or so but regardless of that id like to be able to have some sort of control
and seeing the boost that high with the bc switched off (im sure the solenoid is dead) it still spits out that much boost which i can only see being the actuators
ill have to research a bit more i guess
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5641982
Ok it seems the ebc solenoid has died and jammed right open
when i take it off i will look inside
I thought when you said it was all disconnected it wasn't physically inline with the turbo anymore, they should be a fail safe solenoid but if it jammed open then that makes sense.
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5643675
oh i meant i disconected the in car controler sorry
yep i have also checked the power to the solenoid there was a reading
so the swing valve is jamed open
i cant wait to open it to learn what is inside after i remove it
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5643878
dude you are getting "unlimited" boost which means either a line is off somewhere or you have not hooked up the system properly. what's happening is no pressure signal is getting to the wastegates so they are staying shut the whole time. you need to check, and recheck your hoses. no way would the wastegates come set over 1.5bar. well it's possible but extremely unlikely. it's a plumbing problem.
if the solenoid is jammed open it's possible it's bleeding off so much air that you are getting unlimited boost but the solenoid from memory should be NC type so if not working it should be closed and you just get base boost.
  • Like 1
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5643905
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
