22psi is about what most people would run on that turbo, I'm assuming the motor is build and tuned for that? what is the issue?
You could have a boost line with a leak causing it to go higher than it should though.
Edited by Rolls
  • Like 1
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5641966
cheers for the input
ill check the lines again i replaced one coming off the fpr but that is all good now
my motor is not built for that power level and i don't want that amount of boost which is the root of my concern
my 755 cc injectors and haltech - rail etc etc all go in in a week or so but regardless of that id like to be able to have some sort of control
and seeing the boost that high with the bc switched off (im sure the solenoid is dead) it still spits out that much boost which i can only see being the actuators
ill have to research a bit more i guess
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5641982
Ok it seems the ebc solenoid has died and jammed right open
when i take it off i will look inside
I thought when you said it was all disconnected it wasn't physically inline with the turbo anymore, they should be a fail safe solenoid but if it jammed open then that makes sense.
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5643675
oh i meant i disconected the in car controler sorry
yep i have also checked the power to the solenoid there was a reading
so the swing valve is jamed open
i cant wait to open it to learn what is inside after i remove it
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5643878
dude you are getting "unlimited" boost which means either a line is off somewhere or you have not hooked up the system properly. what's happening is no pressure signal is getting to the wastegates so they are staying shut the whole time. you need to check, and recheck your hoses. no way would the wastegates come set over 1.5bar. well it's possible but extremely unlikely. it's a plumbing problem.
if the solenoid is jammed open it's possible it's bleeding off so much air that you are getting unlimited boost but the solenoid from memory should be NC type so if not working it should be closed and you just get base boost.
  • Like 1
https://www.sau.com.au/forums/topic/351695-2860-5/#findComment-5643905
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
    • What I’m saying is that I never heard of a non gtr 34 coming with a cooling panel stock or factory option. Maybe they might’ve I don’t know
