Hi guys,
I am wondering if any fellow gtr owners (r32/33) who are running a PowerFC Djetro. would be able to help me out.
What i need is you to post the serial on your PFC and then the serial on the back of your hc.
Reason i need this is i have a PFC Djetro (PFC GTR33D 020-0141) however my hc does not work with it and does not have a serial on the back so i have no way of working out which model will work with my pfc
Cheers
https://www.sau.com.au/forums/topic/351704-favour-from-gtr-owner/
covered in the PFC FAQ in my signature
it has a list of what model hand controller to get
in a pinch if you go for the new EL hand controller it will work
otherwise you must match the exact version, given its the new GTR djetro you i think need is product part # X001 which is FCC3 (sticker on the back)
its easier to go for the EL one as you can be guaranteed its right
thanks paul, i had a read of your website earlier and got abit confused lol. Was hoping to not have to go the EL hc as they are $400 :(
if the serial was RB26xxxxx then you would need FCC NT
so i suspect the hand controller you have is to suit RB26xxxxx SERIAL # and not GTR33Dxxxxx
so you can probably safely sell yours as FCC NT
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
