Seems to be a pretty good thing, but when he says "everything" has been replaced 2000k ago... That's tens of thousands of dollars, excluding motor and gearbox, as the bloke on here who really has restored one will attest
Yes, true. He says he has all receipts though, so I'll wait to hear from him.
if its what he says then go for it. good price......but it does say always kept under cover, and its outside in the rain for the Photos...
i doubt it has been restored to the extent that the one here on the forums has been (that is just nuts and i cant find the link off the top of my head).
But either way, for 22 grand with that list and those Km's and it runs well with reciepts (if he has em) you cant really go wrong :)
Haha, yeah I thought it was a bit ironic that its sitting out in the rain, I'm assuming he just put it out there to take photos, and it's in QLD so hard to avoid rain lately
basically that's what people say when they car is kept in a garage at night. it doesn't mean that it has never been out in the rain, etc. if you were to take "it's always kept under cover" literally then it must mean that whenever it is driven he has some sort of cover over the top of it, or only drives it in an under ground carpark.....
so it's always kept under cover, except for when it isn't.
f**k that is cheap for being "restored", i'm actually restoring my 32 4 door atm and passed that asking price ages ago just getting door seals. Would be good to see some more pics
The colour of the seats is not to everyone's taste. However, no-one ever goes to that much trouble unless he/she's an enthusiast
However, he/she doesn't say that the restoration was actually done by him/her. The English simply says "...my restored..."
It's worth looking at - and your enquiry might pay off; but I'd check on how long he/she's had it and when you look at the work receipts, ask for permission to check all details.
Seems strange that it would have one when its got N1 turbos aswell. Pretty overkill for that kinda power level
vcam is worth like 25% of what he is asking for the whole car
pull the other one terry ;)
we all know that tacky leather seats are just as common on fully sick bro cars that get THRASHED as they are on enthusiast cars
if you go look at it take a screwdriver with you and check the inside of the sillsbehind the carpet. if it has had the full resto then those should not have any rust in them.
seats do not belong to that car. the label on the side is an airbag label so the are out of somethe later.
I would ask for every receipt available. I can tell you now that if it was done right he will produce a BIG pile of receipts totally at least $20k.
also take a fridge magnet so you can look for bog.
    • My R33 never ran more than stock boost but it was unclear whether the turbos would last. Maybe OP's car is less of a question mark but for my stock turbos had over 175k km on them + 25 years of use. That's a very long time to hope nobody has ever accidentally put physical shock through them, no debris in the exhaust gas stream, no boost leaks that could cause the compressor to spin faster than it otherwise should, no oil coking in the journals, no wear scars for any reason, etc. You could pull the turbos and disassemble to inspect/overhaul as needed but for that kind of effort you may as well replace the ceramic turbine with something that can take a bit more abuse no matter what you find in there. Stock boost ceramic turbos really don't make that much power either.
    • A Pillar forward?   The part above I was just looking at was the reo bar, I'd replace it, UNLESS the panel beater is GOOD. From your early photos, it did look like the chassis might be tweaked, or at the very least there was tweaks in radiator support. I'd personally do a new / second hand unmolested reo bar, and drill it, only so I know underneath the pretty painted front bar, there's not a mess of other metal that's been hit and smacked.
    • Yes no yes. Pineapple rings do do a certain amount of subframe "locking up", in that they do add some resistance to lateral movements. But the primary reason they exist is to alter the driveline angle. Depending on how you install them you can either increase or decrease rear traction __ a little bit __ by changing the angle of the lower control arms relative to the car/pinion angle. The thing is, given what they are, how and where they are installed, their lack of engagement with anything in particular, there's a limit to how much benefit they can offer. The GKTech collars put metal into the space in the stock format bushes, thereby limiting how much give they have. The rubber is still there to take up some force, albeit perhaps preloaded a little by having some extra metal jammed up into it, but the increase in stiffness comes from making it so that the stock format bush can't deflect that large bit of rubber over into the space adjacent to it, in any direction. Top AND bottom. Which the pineapples certainly do not do. As I said in my other thread - I'm convinced.
    • Also, if you're into customizing your ride, you might want to check out tesla accessories model y for inspiration on screen integrations and functionality.
