Hi guys,
It looks like I need a radiator for my S2 Stagea, the one in the car is leaking.
I've done a search on the forum but was unable to find a part number for it.
I found few topics here where people were talking about several options (ebay, koyo and so on). I would prefer direct replacement and put a standard or better one, but I dont want to go for manual radiator + external tranny radiator. might be the better option from performance point of view, but at this stage I prefer to "keep it simple" :)
So, my question is - what (and where) do I need to buy? Should I look for S2 radiator specifically or R33 or stagea S1 radiators can be installed ? 36 mm, 40 mm or 52 mm ?
They were talks on the forum about ASI radiators from ebay, like http://cgi.ebay.com.au/52mm-Alloy-aluminum-radiator-skyline-R33-RB25DET-GTS-T-/280580988112?pt=AU_Car_Parts_Accessories&hash=item4153ee1cd0. They are well priced ($199 delivered) but I am afraid they suit manual cars only. Am I right ?
Any help will be appreciated :)
https://www.sau.com.au/forums/topic/351768-radiator-replacement-help-needed/
  • Replies 42
Posted Images
why dont u get the 1 u have now repaired?
natrad or some1 like dat should be able to do it. other wise just talk to a nissan dealer
From my experience, the cost of repairing the unit is not that much lower (I might be wrong). Plus you end up with old unit, and you never know how long it will last.
Nissan dealer is obviously an option, and I will approach one tomorrow. Just want to know what else can be done.
I am sure the correct answer is the obvious one. Go your radiator shop and ask for a new one. Even if they have never heard of a Stagea they should be able to look through their Natrad catalogue and find one for you. They simply match the shape, position of the inlet & outlet make sure it has the heat exchanger for the autoetc and they should come up with the right one.
My radiator packed it in this week aswell, new one from Nissan is 700 bucks and 3 weeks wait, I got lucky and got a second hand one from just jap so maybe call around and ask if anyone has one otherwise like the others said upgrade to an alloy radiator and get a separate transmission cooler as if u have to go through Nissan in the end cost will end up similar anyway so u may as well upgrade, alloy radiator from just jap is 300 bucks don't know about trans cooler though, oh and if u check out the first page of the parts list someone mentions replacing their radiator with an r33 one and quotes a part number if that helps
Edited by Chris_Beli
alloy radiators are good for cooling bit i know by fitting lots when i worked at jshop
that they also crack easy
nothing beats a stock 1.
i would take ur old 1 to natrad and see how much its going to cost to fix.
they can also flush it out and pressure test it
cant hurt to try.
Unsure of what State OP is in, but in Adelaide we have JayRad who sell Denso parts; I took my old (auto) radiator to them and they measured it up and found a replacement with trans cooler but ~2 inches thick overall (original is about 1 inch thick I think from memory, a bit undersize IMHO). The new unit was somewhere around $300-350.
Hi Dave
my stock Rad is 16mm thick,
we have sorted new one 25 mm core,
will post more Details for all,
but as this is WA it maybe good for any one looking this side,
Cheer`s Chuckie.
well its sorted 25mm thick core, jap made,
fitted with 1 years warr, flush & coolant $400 ,
ANDERI will post more info soon,
this is in WA :cheers::thumbsup:
so hope you boys can get sorted in EAST :3some:
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
